Author Topic: Construction math Can't Figure it out Help me  (Read 4548 times)
nullb0y
  • Slow In Fast Out
    • WAT Racing
« on: August 22, 2002, 02:42:06 pm »
I WANT TO MAKE A CONTROLL PANNEL WHERE THE BOTTOM IS 18 IN BY 9 IN THE SIDES NEED TO BE SLANTINGSO THAT THE FAR BACK IS 2 IN HIGH AND THE FRONT IS 1.5 IN HIGH
FRONT PANNEL WILL BE 1.5X18 IN AND BACK WILL BE 2 IN BY 12 WHAT WILL THE TOPS DIMENTIONS BE FROM THE SLANT HOW MUCH LARGER THEN THE BOTTOM ?IN BY 12 IN
its almost the same i will jsut add a quarter inch i think
« Last Edit: August 22, 2002, 04:26:02 pm by JustMichael »
Slow In Fast Out
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
Re:CONSTRUCTION MATH CANT FIGURE IT OUT HELP ME
« Reply #1 on: August 22, 2002, 02:45:32 pm »
The easiest way for you to figgure this out is to make a full size model from cardboard and measure it.
I wouldn't trust anyone's math, unless I knew him really well.
Bob
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #2 on: August 22, 2002, 02:46:49 pm »
OK I GUESS I BETTER DO THAT THEN.... THANKS I WAS JUST ABOUT TO DO THAT LOL
Slow In Fast Out
rosco
  • Last login:August 04, 2003, 02:59:07 pm
« Reply #3 on: August 22, 2002, 03:47:18 pm »
use the pythagorean theorem
9 inch deep bottom, 0.5 inch rise
9^2 + 0.5^2 = top^2 or
9.014 about 9 1/64 inch deep top
but you are using a lot of different dimensions (16 wide then 12 wide or deep?) in your post so if that's not right just substitute the real depth of the bottom and the real height difference between the back and front pieces for the calculated depth of the top piece
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #4 on: August 22, 2002, 04:05:36 pm »
i messed up a mit there i made a carboard model this should work
this is how its gonna look i guess...
Slow In Fast Out
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
Re:Construction math Can't Figure it out Help me
« Reply #5 on: August 22, 2002, 07:36:57 pm »
---gosh-darn---..i love how your thing look man..
very cool.... :)
« Last Edit: August 22, 2002, 07:37:17 pm by SNAAAKE »
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #6 on: August 22, 2002, 07:54:45 pm »
you really like it lol ima wire the box up to make shure i like it when i get the switches ect
Slow In Fast Out
SNAAAKE
  • -Banned-
« Reply #7 on: August 23, 2002, 03:39:32 am »
i liked how it said.."PLEASE SUBSCRIBE AND PAY'..other wise joystick look okay..but honestly..i am not fan of 1p panels.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #8 on: August 26, 2002, 02:54:49 am »
yeah soem times the thing messes up my pics but if u reload they work most of the time from now on ill just post urls
Slow In Fast Out
hyiu
  • Last login:August 29, 2014, 05:36:15 am
  • too many games... too little time....
    • www
« Reply #9 on: August 26, 2002, 10:53:06 am »
plz be careful about the height of the thing....
if its only 1.5 in high, it might not be enough for the stick
and the buttons... (definitely not enough for verticals...
not sure about horizontals....)
also.... keep in mind thickness of the boards....
or else you'll be off a bit also....
;)  ;D
Another Brilliant mind ruined by education....  :p
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #10 on: August 27, 2002, 02:01:03 pm »
OH SH*T YEAH how tall are buttons and sticks i guess i better make it 2.5 in in the front and 3.5 in the back.... ima try my cardboard thing first
Slow In Fast Out
hyiu
    • www
« Reply #11 on: August 27, 2002, 02:24:31 pm »
if you're using super/competition stick with horizontal buttons, then 2.5 in should be good....
if you're using vertical buttons... you *might* need a little more... you can go to the Happs site... they have mounting views with all lengths... so, you'll know....
;)  ;D
Dink
« Reply #12 on: August 27, 2002, 02:25:14 pm »
Man!  My head hurts.  That thread was hard to read. :)
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #13 on: August 28, 2002, 06:15:04 pm »
ima go with 4 inch front and 6 inch back 2x4 and 2x6's lol easy pleasy!
Slow In Fast Out
Darkade
  • Last login:November 10, 2003, 06:40:10 pm
  • We Are 138.
    • Darkade Mame Arcade
« Reply #14 on: September 02, 2002, 02:33:49 am »
When that stick is all finished, maybe you can start work on some punctuation.   :P
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #15 on: September 02, 2002, 02:49:49 am »
18" in front and 12" in back?
Well, you were given the answes.  I could give mine if you want mroe mathimatical proof.  I did graduate as an Applied Math major.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #16 on: September 03, 2002, 04:14:38 am »
this threaqd needs to die i got the math donwn and it is built but lol i miss measured 1 thing by an inch so im gonna recut it uh thats it lol  the end! lol
Slow In Fast Out
