Author Topic: Anyone using plexi/lexan to cover side art? Need advise.  (Read 1361 times)
big_garryb
  • Last login:June 09, 2006, 08:08:12 am
« on: June 24, 2004, 06:15:35 am »
Hi,
i had decided to use thinner wood and off-set the groove for the t-mold. This seems to work fine. as it covers joins.....
i planned on covering the side panels (see pic) with plexi/lexan to protect the artwork. the t-mold will fit snuggly with 2mm plexi/lexan covering........... but now i decided to price up the plexi and its gonna wap
oh dear - not rain again......Scottish weather is crap, oh well - at least Mame can keep me company.
big_garryb
Re:Anyone using plexi/lexan to cover side art? Need advise.
« Reply #1 on: June 24, 2004, 06:17:18 am »
sorry, doesnt want to let me add the pic...... i will try again..........
Grasshopper
  • Last login:March 04, 2025, 07:13:36 pm
« Reply #2 on: June 24, 2004, 08:11:57 am »
It's the risk factor that would put me off. One scratch and you've wasted a lot of money.
But if you're skilled (and lucky!) enough I'm sure the end result would look good.
DaveMMR
« Reply #3 on: June 24, 2004, 09:08:25 am »
I personally think it's not even worth the trouble.  Covering the CP is one thing since it gets a lot of hand contact but the sides is not in that same type of danger.  Also, it may look a little odd.  There are alternatives to protect side artwork that's a lot easier and cheaper.
« Reply #4 on: June 24, 2004, 10:19:35 am »
What are they?
Mr-Megalo
  • Last login:July 13, 2006, 08:36:28 am
  • Piano fingered Capcom Addict
« Reply #5 on: June 24, 2004, 11:07:07 am »
yea dont lexanise your sides, use laminate or get some sideart laminated at a screenprinters
big_garryb
« Reply #6 on: June 24, 2004, 03:47:18 pm »
ok - but ive already got the t-mold track cut out..... and the t-mold put on will have a 2mm overhang
should i get some 2mm wood (does wood come in 2mm?) and stick that on? and then get the artwork stuck on over that? or re-do the whole top half of the cab - which i dont really think my nerves could take.........
thanks for the advise so far........
garry
Hoagie_one
  • Um....whats a cabinet
« Reply #7 on: June 24, 2004, 04:46:43 pm »
I once thought it would be cool routing into the sides of a cab, like a poster sized square about 1\8 in deep, placing the artwork in the routed area and filling the square with a 1/8" peice of plexi.  Also that way you could change side art rather easy.
Xiaou2
  • Last login:Yesterday at 10:15:39 pm
  • NOM NOM NOM
« Reply #8 on: June 24, 2004, 07:25:38 pm »
 You could also get something called Mylar.  A think plastic sheet film that youd overlay onto the sides.  However... its expensive as well... and prolly less durable than plexi.
