Author Topic: Madcatz wheel, using PSx / USB in mame?  (Read 3902 times)
Mikee0
  • Last login:August 13, 2004, 05:35:46 pm
  • Do I not look like Jean Chretien?!
« on: June 17, 2004, 09:52:34 pm »
Hello , Ok I have an old Mad catz wheel for a PS1 and i want to use it in MAME , will this work through a USB/PSX converter?
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
Re:Madcatz wheel, using PSx / USB in mame?
« Reply #1 on: June 18, 2004, 07:07:42 am »
Should do I think - if the converter lets it work in windows, then it will work in mame. (in theory). Do a search for "driving controls" - its a bit more complicated than it first appears.
 Arcade driving games use wither a 360 degree wheel (free spinning, does not return to centre - super sprint, pole position, super off road etc..) or a 270 degree whell (doesn't turn full circle, returns to centre - spy hunter, roadblasters, outrun) and apparantly using one with the other does not work well. Your psx wheel will be a 270 (I believe) and should work with those games.
Having said that I don't use psx kit on a pc, so I'm assuming there is a driver that works in windows that is used with the converter box to allow it appear as an input device that windows recognises.
Lilwolf
« Reply #2 on: June 18, 2004, 08:24:28 am »
I use my actlabs steering wheel with a psx->usb converter (because I couldn't get the gameport carts to work).
Anyway, it works fine in mame.  But I found that they conversion defaults didn't work well in some PC games..
And that sucks because PC driving games are really better then most emulated driving games (that work on a real system).
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
« Reply #3 on: June 18, 2004, 04:34:38 pm »
Just psx wheels should work fine but universel one won't(yes tried).
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« Reply #4 on: June 18, 2004, 04:45:21 pm »
These 2 are compatible with EVERYTHING (Wheels, dance pads, controllers, first and third party)
http://www.electricquarter.com/psjoy.htm
http://www.electricquarter.com/ps2dualcont.htm
These 2 work with controllers, the support for dancepads and other peripherals have been mixed, some work, some don't depends on the game, system, and peripheral.
http://www.electricquarter.com/psusb.htm
http://www.electricquarter.com/ps2quadcont.htm
Hope that helps!
BYOAC users get 5% off with coupon code byoac5
Mikee0
« Reply #5 on: June 18, 2004, 07:50:51 pm »
Thanks for the replys and links , I ordered a PSx to USB should be a couple of days.
I'll post the outcome after its arrival.
Too bad about the Pc games , was looking forward to some   NFS Hot pursuit.
Mikee0
« Reply #6 on: June 19, 2004, 09:52:37 am »
also what about the pedals , do you guys think they will work? if no one knows I'll post the results I get the dongle.
thanks.
Sylentwulf
« Reply #7 on: June 19, 2004, 09:26:41 pm »
It really all comes down to wether the drivers you use, and most importantly, the SOFTWARE/GAME you use full support it.
SNAAAKE
  • -Banned-
« Reply #8 on: June 19, 2004, 09:50:20 pm »
The button pedal registers as buttons so yeah they will work.I have a crappy ps1 steering wheel and I did test it out.Worked fine
Mikee0
« Reply #9 on: June 20, 2004, 11:34:45 am »
cool, no doubt after a week or 2 using a 270 i will be wanting to open up and attach an optical to read the shafts rotation, try making it a 360 .
MrBond
  • Last login:March 10, 2012, 03:50:37 pm
  • ...The name's Do......Mr. Do!...
« Reply #10 on: June 20, 2004, 11:48:47 pm »
Does this spoil the 270 functionality?  ie having the wheel turn back to neutral position?
...they only live twice!...
(>")>----MAME----<("<)
