Author Topic: how does one use real speakers in a Mame cab  (Read 9124 times)
Hoagie_one
  • Um....whats a cabinet
« on: June 11, 2004, 09:09:24 am »
How do you hook the speakers up and amplify them from a PC?
« Last Edit: June 11, 2004, 09:09:42 am by Hoagie_one »
BobA
  • What Me Worry?
Re:how does one use real speakers in a Mame cab
« Reply #1 on: June 11, 2004, 11:41:24 am »
If you dont want to use the usual computer speakers you can feed the line out of your audio card to a stereo amp of any type and run the speakers from that.   The if your audio card has other types of outputs some adjustment of your levels may be required.   Always start low and work up do you dont blow anything.
BobA
Hoagie_one
« Reply #2 on: June 11, 2004, 12:49:29 pm »
any suggestions on cheap amps and speakers?
Any hook up diagrams or how to's avaliable?
Wenis
  • Last login:March 02, 2026, 07:02:12 pm
« Reply #3 on: June 11, 2004, 07:57:17 pm »
http://www.mameworld.net/massive/How-to/Amp_Install/amp_install.html here is a real good tutorial on how to install  an amp and regular speakers to a cab.
Like Burt Reynolds!!
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
« Reply #4 on: June 13, 2004, 06:01:42 pm »
http://www.oscarcontrols.com/speaker/ - I am not sure exactly what you are looking for, but I used this tutorial.  I think they sound great for arcade games.
krick
  • Gotta have blue hair.
« Reply #5 on: June 20, 2004, 01:54:09 am »
I'm totally happy with my current setup.
I'm using 5 watt shielded arcade speakers in my cabinet that I bought from Bob Roberts (http://www.therealbobroberts.com/) for $4.00 each...
...connected to my PC using an amplifer taken from a hacked up pair of USB powered Benwin PC speakers.
« Last Edit: May 30, 2005, 11:39:30 pm by krick »
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Apollo
    • Eight Bells
« Reply #6 on: June 22, 2004, 08:43:52 pm »
I have 2 10W shielded speakers, Kiosk amp from Happ with 12V DC 1.5amp power supply and it kicks ass.
Expensive way to do it but hey ya can't take it with you.
krick
« Reply #7 on: July 02, 2004, 12:46:33 am »
I've updated my diagram to what I believe is a better wiring scheme using 4 pin molex connnectors. and a design that will send mono JAMMA output to both speakers (dual mono)...
I'm not totally settled about the wire order in the molex connectors.  The "soundblaster" style CD-ROM audio connector always had the two negatives together in the middle.  That way, if you plugged it in backwards, the worst that happened is that the stereo image was reversed.  With a true molex connector, you cannot plug it in backwards so that shouldn't be a problem.  However, not everyone will use a connector that can only be plugged in one way so it might be a good idea to put the two negatives together in the middle.
Any thoughts?
« Last Edit: July 02, 2004, 12:48:52 am by krick »
Hantarex Polo 15KHz
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
« Reply #8 on: July 02, 2004, 10:07:28 am »
I gutted a pair of 120W PMPO speakers. Took the 4" 5W shielded woofers out and dumped the tweeters and used the transformer and amplifier board to create a new setup. It has two TDA2030A amp ICs which are rated at 18W each. Didn't know crap speakers could actually be set up later and be worthwhile!
I love the life I lead. I wish I could afford it.
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #9 on: August 11, 2004, 11:24:37 pm »
I had a pair of polk car audio speakers laying around.. paid about 160-180 for them but did not put them in my car (long story)
So instead of letting them go to waste i'm going to use them in my cab.  I have already played mame on them without problem.  (stand-alone not in a cab)
went from: digital out on soundcard -> receiver digital input -> speakers.
They go louder than I would want to listen to.. and the silk tweeters make the highs pretty smooth..
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« Reply #10 on: August 12, 2004, 04:07:13 pm »
I bought 2 of the 10W 4" speakers from Happ, and then bought a 2 X 10W stereo amplifier kit from electronickits.com.  I powered it using the 12V power from my computer then just ran an audio cable from my sound card to it.  I used a wall-mount volume control between the amp and the speakers.  Sounds awesome, very authentic!
daywane
  • GRRRR!
« Reply #11 on: August 18, 2004, 10:04:33 pm »
I bumped into a seround sound sytem in a yard sale.
It was made to hook up into a vcr or dvd player.
I hade a 5.1 seound sound card in my pc. so I bought it for $30.00.
Works GREAT. I do not have center chanel working though. it works  on the vcr but not on the pc.
not to bad though for $60.00
30 for card and 30 for system.
gumby510
  • Last login:November 17, 2022, 09:19:44 pm
  • SR-20 NX 2000
« Reply #12 on: September 23, 2004, 07:17:19 pm »
this is a very helpful guide!!!
Bump to the top
