Author Topic: WinCab Jukebox question...  (Read 11295 times)
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« on: May 27, 2004, 09:30:54 am »
When you run WinCab jukebox, the mouse cursor is visible.  Is there a setting in the jukebox.ini file to make it invisible that I am missing?  When I run the program on my arcade cab, I just move the cursor to the edge of the screen so you can't see it, but I'm about to build a dedicated jukebox, and I won't have a mouse available to move it off screen on that so I really need to make it disappear somehow.
Last night, I even tried writing a wrapper in VB that makes the cursor invisible, runs JukeWin.exe, then makes the cursor visible again when you exit JukeWin.exe, but the cursor was still visible in WinCab, it was only invisible when mousing over the VB form.  So much for that idea.   :-\
« Last Edit: May 27, 2004, 09:32:35 am by RacerX »
Chris
  • Moderator
    • Chris's MAME Cabinet
Re:WinCab Jukebox question...
« Reply #1 on: May 27, 2004, 01:24:04 pm »
I'm guessing you're using Windows XP?  I do turn off the cursor, but XP doesn't seem to honor it.  :(  This is an issue with the Allegro library that I'm using; I'll see if a more recent version gets around the problem, as I now have XP on my development machine.
Otherwise, if you're doing a dedicated jukebox, you could set the Windows cursor to blank, or perhaps to a single dot that you'll only see when you're looking for it.
If it's not XP, let me know what you're running...
--Chris
--Chris
Thenasty
  • Trade Count: (+17)
  • Last login:December 01, 2025, 04:30:09 pm
« Reply #2 on: May 27, 2004, 01:53:19 pm »
what about not hooking up a mouse. I don't remember if the pointer is visible when there are no mouse connected.
Free VGA Breakout Cable
Chris
  • Moderator
« Reply #3 on: May 27, 2004, 02:02:03 pm »
I'm pretty sure it is....
--Chris
RacerX
« Reply #4 on: May 27, 2004, 02:48:35 pm »
--Chris
Yes, sir.  I'm using XP.  Thanks very much for looking into this for me, and, duh, I don't know why I didn't think about just changing my mouse cursor to a period.  Thanks for the idea!
  • Last login:Today at 06:25:57 pm
« Reply #5 on: May 28, 2004, 04:36:53 pm »
Hehe... learn about the windows interface.  A new cursor is created for every form in windows and control of said cursor can only be done locally (within the form or application).  This is so when you download a badly coded program and it doesn't restore the cursor upon exit, you don't have to restart windows.  :D
However, most programs draw the cursor from the current theme in windows.  So how you write a wrapper that your talking about is as follows.....
1.  Make a new cursor scheme with all transparent cursors.
2.  Write a module in vb to change the current cursor scheme.
2b.  Write a module in vb to detect the current cursor scheme.
3.  Write a wrapper that records the current scheme, changes the scheme to the "blank" one you made, launches a program, and upon the program's exit, changes it back to the last scheme you recorded.
However, this is DANGEROUS.  If your code is bad and for some reason the cursor doesn't change back, you'll have to boot into safe mode to get a cursor again and manually change the scheme back.  Also, sometimes safemode doesn't change the cursor, and then you'll have to hunt and peck to naviagte to the properties page.
Hope that clarifies things,
HAC
RacerX
« Reply #6 on: May 28, 2004, 06:41:08 pm »
<snipped>
HAC
It appears that WinCab jukebox does not do this.  I just use the default Windows XP cursors.  But when I run WinCab jukebox, the cursor is slightly smaller and black in color.
In fact, Chris had suggested that I make my cursor a single dot, which I tried.  WinCab jukebox still changes the cursor to a small black arrow.
So while the method you suggest would work for most things, unfortunately, it won't work for this.
Thanks, though.
Chris
  • Moderator
« Reply #7 on: May 29, 2004, 08:51:51 am »
If you're seeing the small black arrow, then it's a bug in my code.  I'm in the code right now; I'll see what I can find.
--Chris
--Chris
RacerX
« Reply #8 on: June 01, 2004, 02:03:07 pm »
--Chris
Thanks, boss.  I appreciate you looking into this.   :)
Chris
  • Moderator
« Reply #9 on: June 03, 2004, 09:17:33 am »
I found a solution to the problem; the fix should be in the next version.
--Chris
--Chris
RacerX
« Reply #10 on: June 03, 2004, 12:49:45 pm »
--Chris
You da man!
