Author Topic: Button Colors - Ultimarc Buttons  (Read 1912 times)
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« on: May 23, 2004, 01:07:41 am »
Does someone have an image of the actual colors of Happs buttons or Ultimarc buttons?  Also, all I've read about are Happs buttons.  Has anyone used Ultimarc's, and if so, was there a difference or some reason to recommend one over the other?
Grasshopper
  • Last login:March 04, 2025, 07:13:36 pm
Re:Button Colors - Ultimarc Buttons
« Reply #1 on: May 23, 2004, 10:36:49 am »
Happ's and Ultimarc's buttons are made by the same company:
www.industrias-lorenzo.com
There are some pictures of their buttons on their website.
DrewKaree
  • HAH! Nice one!
« Reply #2 on: May 23, 2004, 10:51:36 am »
Do you have a different link or something?  All I get is
"Forbidden
You don't have permission to access / on this server."
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #3 on: May 23, 2004, 10:56:40 am »
Oh they are the same? I thought I read in another thread that the happ buttons took less force to depress. That might just be the switches though.
DrewKaree
  • HAH! Nice one!
« Reply #4 on: May 23, 2004, 11:05:19 am »
I think I was reading something similar, but I thought it referred to the joysticks.  I knew they carried joys, but I didn't know about buttons, and the button they show as an example is along the lines of the color I am looking for, that's why I ask about colors for both.
Witchboard
  • Last login:January 05, 2022, 09:09:24 pm
    • Oklahoma Coin-Operated Collectors
« Reply #5 on: May 23, 2004, 08:28:17 pm »
Bob Roberts has a pic of all the Happ pushbuttons on his site.  I'm not going to link directly to the pic, but it's easy to find on his parts page.  Click the link that says buttons and you're there.
http://www.therealbobroberts.com
Halfling
  • Last login:September 17, 2004, 04:55:49 am
    • DDRNL
« Reply #6 on: June 23, 2004, 10:14:30 am »
does anyone know whether you can order directly from lorenzo? they don't have any shopping cart options...
What does *this* button do?
Witchboard
« Reply #7 on: June 23, 2004, 11:26:39 am »
You can probably order from them, but there's probably a minimum order that is several thousands.
pointdablame
« Reply #8 on: June 23, 2004, 01:35:06 pm »
yeah, didn't someone here consider buying some buttons straight from IL and the min order was something like 5000 buttons??  I seem to remember something like that.
first off your and idiot
mahuti
« Reply #9 on: June 23, 2004, 03:09:03 pm »
I have some ultimarc buttons. Generally they the same. The switches might be a bit different, but not noticeable during gameplay  if they are placed side by side in the same cab.
Minwah
    • MAMEWAH
« Reply #10 on: June 23, 2004, 03:15:08 pm »
Ultimarc now use Cherry microswitches, which I'm pretty sure Happ also use.  I think U'marc used to use Honeywell microswitches, which I like (I also like the Cherry's), but the two have quite a different feel.
MinerAl
  • Last login:January 27, 2025, 07:02:58 pm
  • duck
« Reply #11 on: June 23, 2004, 08:42:43 pm »
Unless something has changed lately, Ultimarc switches require .25" female quick disconnects, while Happs require .187"
I personally like this because it means the .25" QDs I can get in the autoparts aisle of my local WhateverMart fit perfectly.  The .187" ones are a bit trickier to acquire at 2 a.m.
Zakk
  • Last login:Yesterday at 10:14:36 pm
« Reply #12 on: June 23, 2004, 08:43:34 pm »
I just ordered some Ultimarc buttons, and since I've used tons of Happ buttons over the past couple of years I'll be able to see any differences right away.  They should be here in a day or two, I'll post back when they arrive. (I hope they are the same since they are going in a machine with some Happ buttons I had kicking around!)
Tiger-Heli
    • Tiger-Heli
« Reply #13 on: June 24, 2004, 06:54:01 am »
If you're thinking of what I'm thinking of, that was some Chinese? (Taiwanese?) company selling convex buttons.
I think it's possible to order directly from them, but they are European only, so it's difficult from the states, and I think they only sell to businesses (so you have to work for your own small arcade company).
I think Grasshopper bought from them before, could be wrong, though.
Witchboard
« Reply #14 on: June 24, 2004, 08:33:01 am »
Zakk
« Reply #15 on: June 24, 2004, 09:13:36 pm »
Colors are the same, Ultimarc is smaller with a much stiffer microswitch, oh and that microswitch (still a cherry) has the crazy big tabs on it that fit the minipac wiring harness.
*Edit: Smaller in height, not width, they are identical looking at them from the top.
« Last Edit: June 24, 2004, 09:14:32 pm by Zakk »
