February 26, 2026, 06:00:32 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Main
Audio/Jukebox/MP3 Forum
Sound Stutter, or double sound.
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Sound Stutter, or double sound. (Read 2526 times)
Woodjh
Trade Count:
0
Jr. Member
Offline
Last login:May 05, 2004, 04:35:55 pm
I'm a llama!
on:
May 14, 2004, 11:22:03 am »
Hello everyone, I am having an issue with some sound in mame32. For instance when I play mk2. Sometimes the sound is fine, other times it is delayed, and other times it seems to double up the sound. Any ideas what I might be able to do to fix this. I have a sound blaster live card.
Any suggestions would be great
Joe
Logged
Popcorrin
Trade Count:
+2
Full Member
Offline
Last login:March 06, 2022, 11:11:43 am
Re:Sound Stutter, or double sound.
Reply #1 on:
May 14, 2004, 05:10:35 pm »
What are your system specs? Sounds like you might be short on processing power. During gameplay hit F11 and see if you are getting full fps. If not you can try an older version of mame or upgrade your system.
Logged
Woodjh
Trade Count:
0
Jr. Member
Offline
I'm a llama!
Reply #2 on:
May 14, 2004, 11:15:30 pm »
p4 1.3 ghz, 640 rdram, sound blaster live. ati 7200 64 ddr.
When I hit F11, I am getting 47 to 53fps, max is set at 53.
Sound is really good, it is just annoying to have the late sound, double sounds, scratchy sounds.
Logged
Popcorrin
Trade Count:
+2
Full Member
Offline
Reply #3 on:
May 17, 2004, 08:51:31 am »
Anytime you don't get full fps chances are u will get distorted sound. If it is dropping down to 47fps at times that is when you will get the sound stuttering. The MK series was alot faster in older versions of mame so if you really want to play it I would advise getting mame.72 or a version near that
Logged
AlanS17
Trade Count:
0
Full Member
Offline
Last login:December 02, 2019, 08:35:48 am
I won't even pretend to be clever...
Reply #4 on:
May 18, 2004, 06:22:25 am »
I would recommend manually cutting the sound sampling rate in half. This won't really matter much to the enjoyment of the game anyways since the original sound wasn't THAT great to begin with. You should notice an increase in playability and better (or at least normal) sound.
By the way, why aren't you getting full frame rates? I get full frame rates on a much worse system. I don't use MAME32, though. If MAME32 doesn't work so well you may wanna give fastmame a try.
If this happens with a lot of games or with music the problem may not be MAME. You may want to check for more recent audio drivers or move the sound card to a PCI slot further away from other cards to reduce interference.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
