Author Topic: Joystick issues  (Read 1015 times)
tw661
  • Last login:July 23, 2004, 11:42:39 pm
Joystick issues
« on: April 24, 2004, 07:57:43 pm »
Please I need help.  I just got two new T-Stik Plus joysticks for my cabinet.  I figured this should be an easy swap.  But for some reason.  My stick gets stuck on up when I test it in the IPAC config utility.  What gives?  Must be some wiring issue, but I can't figure it out.
CthulhuLuke
  • Last login:May 22, 2025, 01:03:42 am
  • old school
    • CthulhuLuke's Arcade Parodius
Re:Joystick issues
« Reply #1 on: April 24, 2004, 08:40:09 pm »
triple check your grounding wires, and make sure that A: you don't have one of the wires on Up connected to NC instead of NO, and the two wires (ground and NO) are not touching in any way.
dmsuchy
  • Last login:August 29, 2025, 01:27:50 pm
  • I kill communist llamas for fun.
Re:Joystick issues
« Reply #2 on: April 24, 2004, 08:48:44 pm »
I bet you have the wrong terminals wired, you wire the outside tabs of that joysticks microswitches not the middle one. I made the same mistake!
« Last Edit: April 24, 2004, 08:52:58 pm by dmsuchy »
microwrx
  • Last login:July 06, 2008, 09:22:02 am
Re:Joystick issues
« Reply #3 on: April 24, 2004, 11:35:28 pm »
Yeah, the NO and NC tabs are arond the other way on the T-Stick switches.
tw661
Re:Joystick issues
« Reply #4 on: April 25, 2004, 09:08:27 am »
Thanks guys.  This thing was bugging me.  Everything else worked but the joystick.  It was the switch of the NO and NC.
