Author Topic: LED Resistors  (Read 833 times)
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
LED Resistors
« on: April 06, 2004, 03:07:28 pm »
When soldering a LED to a resistor, does it matter which leg you solder it to?
%$#@!&* machine took my quarter!
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:July 14, 2025, 03:43:29 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
Re:LED Resistors
« Reply #1 on: April 06, 2004, 03:11:15 pm »
No.  It will limit the current wherever it is in the circuit.
« Last Edit: April 06, 2004, 03:11:40 pm by Santoro »
JustMichael
  • Mmmmm!! Cheesecake!!
Re:LED Resistors
« Reply #2 on: April 07, 2004, 12:23:39 pm »
If you are new to soldering I would recommend attaching a clip-on heatsink onto the led wire that you are soldering between the led and where you are soldering.  Leds can be killed by applying too much heat to them.
Oldskool
Re:LED Resistors
« Reply #3 on: April 07, 2004, 06:46:47 pm »
Actually, I've suprised myself.
All is well, as all of the LEDs are functional  ;D
