Author Topic: What to add to a Happ order  (Read 1371 times)
eli curtz
  • Last login:May 26, 2004, 02:51:09 pm
« on: March 09, 2004, 11:57:40 pm »
Hi all,
I'm thinking I'll get one of the "high lip" 3" trackballs from Happ this month while they are on sale and I'm curious if there is anything else I should throw into my order. Are there any particular things you used that you found you could only get from them, or that you assumed you could do without and then changed your mind and had to order seperately? I'll be getting joysticks from Ultimarc along with my encoder as soon as Andy gets the rest of the ball-tops in <waits semi-patiently> so I don't need those.
thanks,
eli
Look. This... is all a mistake. I'm just a compound interest program. I work at a savings and loan! I can't play these video games!
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re:What to add to a Happ order
« Reply #1 on: March 10, 2004, 12:00:05 am »
I've got a 3" Betson highlip trackball for sale for $39.  Cleaned, lubed and tested.
eli curtz
« Reply #2 on: March 10, 2004, 12:12:40 am »
Yeah,
I've considered getting one from you as well. I thought I might have a little more flexibility with a high lipped one since I'm not sure what I'll be covering my CP with (or even if I'll go with wood or metal at this point.)
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
« Reply #3 on: March 10, 2004, 12:50:22 am »
Black bolts/nuts or a mounting plate to mount your trackball??  I found black bolts to be useful and I don't know of may places to get them.   Pushbuttons? Push button wrench?  T-molding?  Monitor bezel?  I dunno, what do you need for your cab?  Those were some suggestions I had.
You can take
dirt
  • Last login:October 30, 2024, 08:36:38 pm
« Reply #4 on: March 10, 2004, 12:56:52 am »
iwould say marquee retainers.
dirt
WANTED: NINTENDO CABINETS WORKING OR NOT
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #5 on: March 10, 2004, 07:00:08 am »
How about Happ Vinyl...Competition Joysticks, Coin Door (makesure you also order 14V #161 light bulbs AND coin mechs for over/under door...
« Last Edit: March 10, 2004, 07:01:41 am by jabba »
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
KrispyTheClown
  • Last login:March 09, 2004, 08:36:07 am
« Reply #6 on: March 10, 2004, 09:25:55 am »
Also, one of those Pushbutton Wrenches are good to have around.  You can get by without one, but they make tightening down your pushbuttons so much easier.  Get the one called the 'Illuminated Pushbutton Wrench' - it has one end that handles regular buttons.  Their website shows the current price at $2.40.
nipsmg
  • Last login:January 20, 2026, 10:46:56 am
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #7 on: March 10, 2004, 09:28:10 am »
Get the mounting plate... Can't stress that enough.  The high lip trackball comes with a spacer that you can use even if you decide to use a metal control panel, or no covering for your wood control panel that still makes it flush.
Maybe a translucent trackball? :-D
--NipsMG
Tiger-Heli
    • Tiger-Heli
« Reply #8 on: March 10, 2004, 10:39:10 am »
I would get everything from www.therealbobroberts.com except Happ rotary joysticks or Perfect 360 joysticks, which Bob doesn't sell.
