Author Topic: Tornado Spinner- How to wire it up to USB  (Read 2747 times)
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« on: September 08, 2023, 04:22:58 pm »
This fell out of a box, no instructions or plug, manual...
 I don't have any plug, but 4 wires, black and white, 2ft twisted in pairs-How do I wire? Some old posts,  nadda-
THANKS!!  ;)
NuclearWarren
  • Last login:November 25, 2024, 09:55:02 pm
Re: Tornado Spinner- How to wire it up to USB
« Reply #1 on: September 08, 2023, 05:14:24 pm »
That doesn't look like the USB version of the Tornado. I have one, and its got a chip etc.
You can plug that into an Arduino Nano, teensy, Micro or some such micro controller, which accepts all manner of inputs and outputs to USB. In the case of a spinner, you'd be making a single axis mouse.
See here:
https://github.com/jandelgado/usb-spinner
In that diagram, the four connections on the 'rotary encoder' are what you've got there (VCC, GRN, A, B).
ws
  • Online Online
  • Last login:Today at 09:22:14 pm
« Reply #2 on: September 08, 2023, 06:12:35 pm »
Here's the pinout for the no-chip optical board on your Tornado spinner.
- Found the filename in AndyWarne's post here and a copy of the image here on archive.org.
tommyinajar
« Reply #3 on: September 08, 2023, 07:02:10 pm »
Hey thanks guys!!
I figured it was an old model. I wonder if there is another one,
 It's not slave master like turbo twist, is it?
tommyinajar
« Reply #4 on: September 08, 2023, 07:14:35 pm »
NuclearWarren
« Reply #5 on: September 08, 2023, 07:37:20 pm »
Thats the way, the price is right!
  • Online Online
« Reply #6 on: September 08, 2023, 09:40:36 pm »
Hey, will a Ultimarc spintrac work ok, right?
https://www.arcaderenovations.com/ultimarc-spintrak-usb-kit.html#262
Yes.  That encoder will work.
Pinout info from the Ultimarc SpinTrak page:
Connection to Opti-PAC
For Opti-PAC connection, the 4-pin connector fitted to the device must be cut off and the wires stripped back. They are connected as follows:
Brown    +5Volts
Yellow    X1
Green    X2
White    GND
Connecting Mouse Buttons
Mouse buttons are connected to 3 pins on the header as shown in the picture below.
The COM connection of both switches should be connected to COM and the normally-open connection of each switch to the LEFT or RIGHT pin.
The bad news is that the pins are in a different order.
The good news is that it's easy to pull the pins out of the Dupont housing to change them around.
- If you have a 1x4 Dupont housing, you might want to use it.
- You may also want to flag both ends of the 5v line so you don't install the cable backward.
tommyinajar
« Reply #7 on: September 09, 2023, 12:29:00 pm »
$7 shipping, same as eBay-
If anyone wants more encoder info here, I'll assume it's accurate.
https://www.instructables.com/Arcade-Spinner/
