Author Topic: Cruis n usa and Cruis n World (MAME) link 2 players?  (Read 50698 times)
jorgenjl2
  • Last login:October 07, 2025, 07:20:28 pm
Re: Cruis n usa and Cruis n World (MAME) link 2 players?
« Reply #40 on: August 11, 2025, 08:39:21 pm »
https://youtube.com/shorts/SO_e-36-JFY
/edit Now I really need to get going and hang this beauty above my cabs!!!  Anyone have a manual on the Cruis'n USA topper? I think I can figure out the voltages but I don't want to accidently let out the magic smoke....
Is this a working leader light and player 1 or player 2 lights up based on whoever is in the lead or does only the marquee light up? I saw pictures of that before but I have never known anyone who has one. If it doesn’t light up individual racers you can use my code and add a led strip to light up the leader if light will shine through the sides. If it does light up, I have no clue Cruis’n had that feature.
jorgenjl2
« Reply #41 on: August 19, 2025, 08:51:06 pm »
I can confirm that Cruis’n World 4 player works great.
I can also confirm that the outputs (race leader light) works. However , when you do a lan game, not only is there the 1/10 race leader, the screen has a new 1/num players (2/4 if in 2nd place and havr 4 racers) as well so I will have to find the memory address for that and update the lua script so the race leader light lights up when leading the other racers instead of needing to be in 1st place of every single car.
Note I did get an error when testing lan (before implementing race leader lights) below but I want to say this was when I only had some of the four racers going and since the Mame.ini points in a circle, I expect this is normal. The next time I have a party I will have to thoroughly test with friends.
Fatal error: Unimplemented op @ 8099E8: 08AD8000 (tb|=045)
jorgenjl2
« Reply #42 on: August 21, 2025, 09:56:39 pm »
Small correction… Cruis’n World does have the multiplayer lan 1 / 4 extra memory address shown on screen. Cruis’n USA only has the x / 10 overall standing on the screen. So for Crusn USA I would have to write the current players position to a file, monitor who is ahead of the other person a few times every second and light up the race leader light based on who is ahead. For now I will leave Crusn USA race leader light code to only shine when in first and for Crusn World I will have to find the memory address for who is in 1st of the four (or three or two) racers.
 Can anyone confirm if force feedback works for Mame Crusn USA and World? Like actually work when hitting other cars and stuff?
Endprodukt
  • Last login:February 10, 2026, 08:33:03 am
« Reply #43 on: August 22, 2025, 03:39:59 am »
Both games didn't have FFB crash effects. They really didn't make much use of the FFB beyond resistance. You can get that working with FFB arcade plugin.
« Last Edit: August 22, 2025, 10:12:13 am by Endprodukt »
SailorSat
  • Last login:February 07, 2026, 07:38:58 pm
    • For Amusement Only e.V.
« Reply #44 on: August 22, 2025, 10:06:13 am »
Race leader lights are output via MAME outputs.
lamp6 / lamp7
lirogames
  • Last login:Today at 08:43:54 am
« Reply #45 on: August 28, 2025, 11:42:02 am »
Would it be great and possible to compile for the 32-bit version? WinXP and such?
Thanks for the initiative Sailor, it was excellent. :)
ArcadeGuns
  • Last login:August 29, 2025, 09:32:10 am
« Reply #46 on: August 29, 2025, 09:32:10 am »
probably both - my latest pull requests are still not merged after half a year.
currently working on offroad challenge.
every v-unit game implements its own protocol, although I can see the logical progression with it .)
Thank you for your hard work. I'm been following all the awesome things that you are doing. Every time you fix things, I'm amazed!
jorgenjl2
« Reply #47 on: August 31, 2025, 08:51:15 pm »
lamp6 / lamp7
Oh so multiplayer lan there was a race leader light back in the day for Crusn? I had no clue. Do you know if this is for both Crusn USA md World? Do you know the difference between lamp6 and7? When I tried it back in the day nothing corresponded to being in 1st but that must be different now that you made this linkable.
SailorSat
« Reply #48 on: September 01, 2025, 02:39:33 am »
not on my part, sry.
in usa those are labeled "left front"/"right front" (i assume headlights on the deluxe cabinets)
in world they are labeled "marquee lamp 1"/"marquee lamp 2"´
in offroad challenge "header upper" and "header lower"
in any case, the leader is blinking, while the others remain still
vertex
  • Last login:October 27, 2025, 09:07:40 am
« Reply #49 on: September 03, 2025, 10:01:40 pm »
i hate the internet sometimes...
http://www.rev-girls.de/cruisnmame.zip
gotta sort out the other webserver issues later...
Great work! The link isn't working. Could you please upload it again?
SailorSat
« Reply #50 on: September 04, 2025, 04:54:34 am »
use http://files.arianchen.de/cabmame/cabmame0279.7z
that also contains the outputs.
AND use a browser that does not freak out if stuff is HTTP only...
vertex
« Reply #51 on: September 04, 2025, 08:06:03 am »
It's my fault, my browser closed automatically when I clicked on the link, I tried another one and everything was fine, thanks for responding and it works fantastic!!!
Zeosstud
  • Last login:Yesterday at 11:59:33 pm
« Reply #52 on: September 12, 2025, 10:46:13 am »
Just wanted to take a second and say Thank You.. Getting these 3 games to link up properly in my little Dual Driving cabinet setup could not have been easier.
Appreciate the effort, SailorSat I hope this gets brought into the official Mame builds soon.
-Zeosstud
anchounio
  • Last login:January 04, 2026, 08:28:56 am
« Reply #53 on: October 12, 2025, 01:22:44 pm »
Any chance we could have a mame build with all your network updates?
Your work is amazing and I hope it gets into official mame soon
