February 12, 2026, 09:36:59 pm
Hey guys, total CRT noob here. I followed the instructions found on various YouTube videos to discharge the monitor but got no pop. I tried using the 2 huge brackets that protrude from the back of the monitor from top to bottom thinking they are a good ground point. I also tried going to a wall outlet's ground pin, still nothing. So I removed the anode cup from the tube without incident. I followed the attempting grounding of both the cap and the exposed CRT hole once again and got nothing.Being totally paranoid here with a question: am I good to go in safely removing the monitor? I'm changing it out to an LCD because there's something about seeing CRT up close that causes me migraines :|
