Author Topic: New Here, Need Help. Modded OG Xbox Wanting to Put In Cabinet  (Read 1419 times)
WlkThruMyMind
  • Last login:January 23, 2023, 04:10:00 pm
« on: January 08, 2023, 01:29:36 am »
Hello all,
I am new here and stumbled upon this site doing research of how to add my OG Modded Xbox to a gaming cabinet. I dont wanna use the xbox controllers, but the joystick and buttons on the cabinet obviously. Is this easy to do, where do I begin, basically how do I do it? I have ten thousands of games all mapped out to the xbox controllers. Is there joysticks and buttons I can just plug them into, or have to soder them, or what? Whats my best option here to get this to work. Thank you for your help and time
  • Last login:Today at 07:37:58 am
Re: New Here, Need Help. Modded OG Xbox Wanting to Put In Cabinet
« Reply #1 on: January 08, 2023, 02:55:11 am »
There are several ways to connect arcade-style controls to an XBox.
Approach #1:
Do a gamepad hack.
This can be a bit difficult if you aren't very good at soldering.
Haruman offers padhacks in his thread here.
http://forum.arcadecontrols.com/index.php/topic,76185.0.html
Approach #2:
Use an Arduino.
- You'll need a USB to XBox adapter cable since the Arduino has a USB connector.
- There are some breakout boards that will make the soldering (if any) easier.
-- With a breakout board like one of these, you only need to solder several rows of pins instead of many individual wires.
-- Many Arduino Micros come with pins already soldered.
- You'll need to load a firmware on the Arduino that sends the control data in a format that the XBox will recognize.
XBOXPadMicro
http://forum.arcadecontrols.com/index.php/topic,152687.0.html
KADE MiniArcade 2.0
- This firmware is more flexible than XBOXPadMicro, but requires some configuration.  Details are in the User Guide.
http://forum.arcadecontrols.com/index.php/topic,154126.0.html
"Input as" column above corresponds to "Port/Function" (white boxes) below.
  • Last login:February 23, 2026, 08:25:01 am
« Reply #2 on: January 08, 2023, 09:29:52 am »
I’m using 4 Minimus AVRs in my cabinet.  I have a hidden toggle switch that flips the player 1 joystick from digital to analogue mode, for those few cabinet friendly games that don’t use the d pad.
Works great.  The power button is permanently turned on and I use a smart strip with my flat screen as the control for the strip.
