Author Topic: AMD Radeon - highest serie with dual analog output  (Read 4436 times)
haynor666
  • retro maniac
« on: June 03, 2022, 06:49:35 am »
What Radeon highests serie (ie 43xx 54xx) has two analog outputs - either two DVI-I (with support for analog output) or D-sub/DVI-I combinations? I was thinking about upgrade slightly hardware with a bit newer Radeon but looks like many modern cards only have either combination of VGA/DVI-D or no analog output at all (only DP/DVI-D).
buttersoft
  • Last login:Yesterday at 07:22:58 pm
  • Is running at 15kHz
Re: AMD Radeon - highest serie with dual analog output
« Reply #1 on: June 04, 2022, 07:54:05 pm »
IIRC Radeon 5000 series is the last to have models with two analog outputs - so, only ancient cards, pretty much. I also remember there being some question about the DMS59 6000 series low-end cards, but they turned out to be rebadged 5000 series cards anyway.
Rion
  • Last login:January 23, 2026, 09:31:32 pm
  • 240p, 480i
« Reply #2 on: June 05, 2022, 03:29:25 am »
If you want to keep the cost down and use a low footprint I recommend the low-profile R7 350/350x 2/4gb Vram. You can usually find these in OEM Brands from Dell.
these work great with a dotclock of 0.
bobbyb13
  • Last login:January 16, 2026, 12:49:41 am
« Reply #3 on: June 05, 2022, 04:21:45 am »
There are 7000 series cards with dvi and vga outputs, so is it possible to get a converter?
Why do you want 2 of the same output?
Granted you need various input monitors, but it makes setup of CrtEmudriver much easier if that is the goal.
« Last Edit: June 05, 2022, 04:25:31 am by bobbyb13 »
haynor666
  • retro maniac
« Reply #4 on: June 05, 2022, 04:37:08 am »
Yeah, I had one card with DMS59 and indeed it was installed in system as 5xxx serie.
Problem is I use two TVs - one for vertical games and one for horizontal games. Since my motherboard has only one PCIe16 unstalling two cards is not an option. It would be costly anyway.
Converter would another option but again adds additional cost.
The main goal of replacing card was to improve of some late Taito Type-X games. Right now I have HD5450 with two DVI-I inputs.
haynor666
  • retro maniac
« Reply #5 on: June 06, 2022, 02:16:38 am »
I've found https://www.techpowerup.com/gpu-specs/powercolor-hd-7450-2-gb.b2142 - PowerColor 7450 and DVI at on pictures is DVD-I.
haynor666
  • retro maniac
« Reply #6 on: June 07, 2022, 05:21:11 am »
http://forum.arcadecontrols.com/index.php/topic,151781.msg1589549.html#msg1589549
It was :)
makya
  • Last login:January 14, 2026, 05:53:17 am
« Reply #7 on: June 09, 2022, 12:12:57 pm »
The VGA output, cable-connected onto these low-profile card are supposed to be low quality. Well that's what I've read somewhere...
On my side I'm still very happy with theHD4870, two DVI-I outputs.
haynor666
  • retro maniac
« Reply #8 on: June 10, 2022, 04:36:21 am »
HD4000 serie was fine in the past but due many problems I had with resolution switching, interlace modes I'll stick with at least HD5000 serie.
Today I tested PowerColor HD6570 and XFX HD6450 - both have DVI-I but sadly no picture through DVI-VGA adapter.
xbrunox
  • Last login:August 30, 2025, 05:03:06 pm
« Reply #9 on: June 10, 2022, 09:27:30 am »
Hi Haynor
on my cabinets I use the latest AMD HD7970 video cards with DVI-I analog output, actually the HD7990 was also made but it is very rare and expensive.
on the 7970 the analogue output is only one. I for my cabinet with two monitors one vertical and one horizontal as in your case I use a VGA switch and drive the signal either on one or on the other monitor.
haynor666
  • retro maniac
« Reply #10 on: June 12, 2022, 06:07:46 am »
Switch is also an option but I prefer to find card with two analog aoutputs. Yesterday I received Asus HD5670. We will se tomorrow if this card will work.
EDIT.
Asus HD5670 gives analog signal on both outputs.
« Last Edit: June 13, 2022, 03:27:30 am by haynor666 »
