Author Topic: Question: How thick should the Plexi be for the Monitor Bezel  (Read 1911 times)
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« on: February 28, 2004, 08:58:59 am »
Hi All,
How thick should the monitor bezel be on a 26" Cabinet opening? Is 1/4" too thick?
Also, anyone out there use Acrylic instead of Plexi?
« Last Edit: February 28, 2004, 08:59:37 am by jabba »
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
J_K_M_A_N
  • Last login:July 08, 2025, 08:22:37 am
Re:Question: How thick should the Plexi be for the Monitor Bezel
« Reply #1 on: February 28, 2004, 09:17:18 am »
I don't have an answer but I just got a little nervous when I was at the main msg board page and I saw this.
J_K_M_A_N
« Last Edit: February 28, 2004, 09:18:50 am by J_K_M_A_N »
Jabba
  • D-Hutt
« Reply #2 on: February 28, 2004, 09:49:57 am »
J_K_M_A_N
I'm not real sure I know what you mean?
Lilwolf
« Reply #3 on: February 28, 2004, 12:51:47 pm »
The thickness really depends on a few factors.
1) How pissed off you get when the moth!r@#!@#  game cheats you!
2) How good you are at martial arts.
3) If you are good at the games to begin with (NOTE:  Two way sword here... if you suck you get pissed... but if you get really really good... then you really really know when the !@# game cheats you... so more direct anger)
4) Do you keep power tools or baseball bats near your cabinet?
5) Did you build arcade quality controls because you have destroyed more then one hand held?
6) Ever get so mad at your keyboard that the keys are flyingup in the air as you pound away?  (sad enough... I had this happen... the computer so cheated me)
7) Repeat the questions for all family members.
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #4 on: February 28, 2004, 12:59:56 pm »
a lot of people use 1/8"
if you spent a lot of time on your cab you're not going to punch the monitor.  Hope that helps.
Jabba
  • D-Hutt
« Reply #5 on: February 28, 2004, 01:24:03 pm »
OK, OK. I have taken my anger management course and feel I can hold my self back a little LilWolf when the Mutants start hoarding  >:(
So 1/8" is the norm. Does it sway at all in the middle or should I care? Has anyone used dark tint on the back side? If so, is it hard to install?
« Last Edit: February 28, 2004, 01:25:56 pm by jabba »
dirt
  • Last login:October 30, 2024, 08:36:38 pm
« Reply #6 on: February 28, 2004, 02:33:20 pm »
i tried to use thicker than 1/8 and you can actually see waves in it  >:(. stick with the thin stuff.
dirt
WANTED: NINTENDO CABINETS WORKING OR NOT
General Zod
  • Last login:June 23, 2005, 03:58:28 pm
  • Banned
« Reply #7 on: February 28, 2004, 08:15:15 pm »
Are you sure you want to go the plexi route? I've had better success in the long run spending a little more up front and getting a piece of tempered glass for the bezel.
You can even get the glass smoked, which will also cut down on eye strain.
Just my two cents.  ;)
Mike
unclet
« Reply #8 on: February 28, 2004, 08:25:22 pm »
I used 1/4" plexi and it looks fine.   I guess I did not want to go with 1/8" (which I did use on my control) for the monitor bezel since it seems to flimsey(sp?) to me.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #9 on: February 28, 2004, 08:35:05 pm »
Yeah, glass sounds better to me too. Plexi might work fine, but glass is even better.
crsdawg
  • Last login:September 13, 2019, 06:10:05 am
  • I plan to live forever, or die trying.
« Reply #10 on: February 28, 2004, 09:37:53 pm »
i've used 1/4" smoked plex on a couple occasions and have no regrets.
here's one example:
J_K_M_A_N
« Reply #11 on: February 28, 2004, 10:57:57 pm »
J_K_M_A_N
That is what I saw on the first screen listing all the boards. I was hoping it wasn't a question for the "Everything Else" board.
J_K_M_A_N
« Last Edit: February 28, 2004, 10:58:52 pm by J_K_M_A_N »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #12 on: February 29, 2004, 06:14:21 am »
Hi All,
As far as I know, Plexi IS acrylic. Acrylic is what the material is called and Plexi is a brandname. Polycarbonate (with brandname Lexan) is another option, but that scratches easier than Plexi.
But think about it, you put glass in your windows. Why not on your cab? Plexi does scratch easier than glass and it can become "milky" over time. Make sure the glass is tempered (and if possible smoked).
« Last Edit: February 29, 2004, 12:08:46 pm by patrickl »
soslo
  • Last login:March 10, 2012, 03:23:36 pm
  • The Governator
    • My website does not have a name yet
« Reply #13 on: February 29, 2004, 12:04:27 pm »
I use 1/4" amber "smoked" plexi and love it. There are a couple of shots here:
http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=16642&start=0
5 MAME cabs and counting...
Ever wonder what full side art looks like?
http://www.aaronmurray.com
Zombie
  • Last login:September 09, 2016, 07:14:59 pm
  • I want to Build My Own Arcade Controls!!
    • zombie's homepage
« Reply #14 on: February 29, 2004, 06:57:40 pm »
im using 3mm smoked and a clear 6mm plexi on top (to protect the smoked stuff).
so 9mm plexi, around 1/2"? in total.
Stingray
« Reply #15 on: March 01, 2004, 10:04:41 am »
I used one 1/8 inch sheet of tinted plexi and another 1/8 inch sheet of clear plexi on top of it. The plan is to sandwich the bezel art between them once I get it printed.
-S
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:July 14, 2025, 03:43:29 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #16 on: March 05, 2004, 09:16:32 am »
See my post about 4 down here: http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=16790 .My safety glass is 1/8 thick.
