Author Topic: Atari Centipede Cocktail Table is experiencing a few problems  (Read 7349 times)
vapuser
  • Last login:October 11, 2021, 09:18:04 am
  • I'd love to get this game working again!
« on: September 23, 2021, 06:33:37 pm »
Good evening all, I own an Atari Centipede cocktail table which is giving me a few problems. The first problem that I’d like to resolve is that the sound out of the speakers is a low pulsating hum. It’s probably relating to a bad cap, but I’m not sure where to look. Does anyone have any suggestions?
This morning, after reading through my Centipede manual,  I decided to removed the Regulator/Audio II PCB board to check all the voltages. I noticed that all the voltages were within range except for two points that showed 36VAC. Each of those voltages were only showing 18.19 VDC and 18.24 VDC. So now I’m thinking that the two 33,000 uf/35v Nichicon caps might be bad. Time to order more parts. Is it possible that these bad caps could be causing the pulsating hum coming through the speakers?
« Last Edit: September 24, 2021, 09:23:35 am by vapuser »
  • Last login:Today at 04:50:34 am
Re: Atari Centipede Cocktail Table is experiencing a few problems
« Reply #1 on: September 25, 2021, 06:33:02 am »
I am going to try to get you some help.
Make sure you have the correct manual.
There are differences I believe in the power section between the upright and the cocktail.
vapuser
« Reply #2 on: September 25, 2021, 10:45:42 am »
Thanks Mike. I tried to upload a short video of the sound that was coming out of the speakers, but it was rejected do to size restriction. Even after opening it with VLC Media player and reducing the size it was still slightly too large. Thanks for your assistance.
  • Last login:Today at 03:54:39 am
« Reply #3 on: September 25, 2021, 11:41:15 am »
Correct.
Here's some of the related info from vapuser's previous thread.
Check out reply 32 for a pic of the underside of the brick. That will show the Bridge rectifier and the big blue cap.
Based on the schematic Mike posted, the cocktail should have a 2 diode full-wave rectifier, not the 4 diode bridge rectifier shown in the upright schematic.
The two types of rectifiers perform similar functions, but are wired to the transformer and C1 differently.
The full-wave rectifier applies a positive to the positive terminal of C1 from whichever diode is forward biased with the negative terminal of C1 tied to the center tap.
- Only one half of the winding is used at a time.
- Orange (ends) to violet (center) = 1/2 of orange to orange
- Think "top pushed up and bottom stays in the middle".
A bridge rectifier applies a positive to to the positive terminal of C1 from whichever diode on the top half is forward biased and applies a negative to the negative terminal of C1 from whichever diode on the bottom half is forward biased.
- Both halves of the winding are used at the same time.
- Think "top pushed up and bottom pushed down".
Correct me if I'm wrong, but it seems like the orange to orange windings for the transformers in the cocktail and upright would be different values for the different types of rectifiers to output the same voltage.   :dunno
nitrogen_widget
« Reply #4 on: September 25, 2021, 01:27:16 pm »
interesting.
Is there a difference electrically in the PCB itself between upright and cocktail or are we just looking at a different configuration in the power supply and audio/regulator boards?
vapuser
« Reply #5 on: September 25, 2021, 06:50:40 pm »
09/25/21
Thanks guys for your concerns, but I addressed that problem last year, please see below:
Good morning all. Scott, thanks for all the technical details of the two types of rectifiers. I had no idea that there would be a voltage difference. So, if I'm understanding this correctly, by using the bridge rectifier instead of the full wave rectifier configuration, the circuit is drawing twice the current. Thus, blowing the fuses across the secondary winding of the transformer. This sounds like why both F2 and F3 fuses are blowing when power is turned on. I'm glad I saved the full rectifier board. I pulled the brick out of the unit again and I'll reinstall the full wave rectifier circuit board tonight.
02/28/2020
TGIF, Good morning all, Happy to report that the above Problem 2 and Problem 3 have been resolved. The MR750 diodes have been re-soldered to the original full wave rectifier board. See Pic below. I retested all the J5 secondary winding output voltages with a load again and all is still good.
Additionally, I hooked the brick back up in the cabinet and removed the J2 jumpers that were in place to bypass the interlock switch and the bottom switch. I plugged in the J2 connection instead and turned the game on. No fuses blew. Now I feel we’re making progress.  I currently have the bottom switch hooked up, but I have the top interlock switch still removed from the circuit.
Moving forward – Tonight, I’ll reconnect that top interlock switch in place and start re-connecting the additional boards. I’ll start with the PCB board. If no fuses blow, I’ll continue to connect the ARII. At that point I’m hoping to see the red power light on the PCB. With the new Transistor and voltage regulator now replaced, I’m anxious to retest the ARII for those missing 5 volt readings. If all goes well, I’ll report back tomorrow with additional more promising news. Have a good weekend!
To bring everyone up to date, No fuses are blowing, the top interlock has been reconnected, the red power light on the PCB board is now lit and all “appears” to be working properly. I’m now getting an image on the screen and I can now play a game “blindly”.  By that I mean that I have no “cursor”. When I roll the ball, nothing appears to move. I took apart the entire roller ball assembly and cleaned all the parts and reassembled.
Additionally, When I’m playing, I’m getting a low pulsating hum from the speaker. I thought I might want to tackle that problem first. So I took the Regulator/Audio II PCB out of the cabinet and checked all the voltages. It appears that all the voltages are within range except the voltages at C9 and C10. Those voltages should be 36VAC. Instead, I’m showing a voltage of 18.19 and 18.24VAC. So, I ordered those 3300uf caps in hopes that the rumbling sound out of the speakers will turn into a normal game sound. Please see attached pics.
vapuser
« Reply #6 on: September 25, 2021, 06:53:03 pm »
Picture of the monitor when the game is turned on.
