Author Topic: What sort of buttons are these?  (Read 2447 times)
mikew72
  • Last login:July 21, 2023, 04:55:55 pm
« on: July 06, 2021, 12:36:26 pm »
Can anyone tell me what buttons these are?  Can I get replacement parts for them, or do I have to replace the whole botton?
Also, what bulbs go in them?
Thanks.
Gilrock
Re: What sort of buttons are these?
« Reply #1 on: July 06, 2021, 12:45:47 pm »
It would probably help to know what panel you pulled it off of.
mikew72
« Reply #2 on: July 06, 2021, 01:04:12 pm »
I guess it would  :)
It's from a Lordsvale Playscene 20 4 slot Neo Geo cabinet.  The black circle is where the old bulb exploded in the button.
« Last Edit: July 06, 2021, 01:15:27 pm by mikew72 »
Gilrock
« Reply #3 on: July 06, 2021, 01:31:18 pm »
Guess it depends on whether you need originals or would be willing to replace with something close.  Maybe someone can tell you how to find something close to the originals.  I just did a google search and found a couple that look close but I don't know what measurements you need.
https://www.allelectronics.com/item/lps-5r/12v-lighted-pushbutton-red-1.5-square/1.html
https://www.walmart.com/ip/Game-Push-Button-50x50-Square-12V-LED-Illuminated-Push-Button-Switch-with-Micro-switch-for-Arcade-Video-Red-2pcs/410653490
https://www.rpelectronics.com/459-522-spdt-square-red-lens-on-on-illuminated.html
« Last Edit: July 06, 2021, 01:33:13 pm by Gilrock »
mikew72
« Reply #4 on: July 06, 2021, 01:45:53 pm »
Thanks.
The problem is, without knowing exactly what they are if I replace just one button it'll probably look slightly different to all the others...  The only solution I can see it to replace them all.
  • Last login:Today at 06:10:27 pm
« Reply #5 on: July 06, 2021, 03:36:14 pm »
Probably easier to replace the whole button than find replacement parts like the diffuser.
They look like the Happ "Small Square Illuminated Pushbuttons" that Divemaster sells.
http://www.arcadeemulator.net/cgi-bin/shop/cp-app.cgi?usr=51F1850962&rnd=3603265&rrc=N&affl=&cip=&act=&aff=&pg=prod&ref=SmallSquareIlluminatedPushb&cat=IlluminatedPushbutton1&catstr=HOME:Pushbuttons:IlluminatedPushbutton1
The bulbs are wedge base, size T3-1/4.
- Original bulbs were probably #161 14v incandescent bulbs running on 12v.  Check the voltage to confirm.
- You might want to use LEDs instead -- longer life, less heat, less current draw.
- If you're ordering buttons from Divemaster, he's also got LED bulbs here.
mikew72
« Reply #6 on: July 06, 2021, 04:09:57 pm »
Thanks.
I'll order one and see how it looks.  If it matches, great.  If not, I'll just get a complete new set...
Tarma
  • Last login:August 18, 2025, 01:20:58 pm
« Reply #7 on: July 08, 2021, 09:18:05 am »
It looks like you have those square buttons as the player buttons on the panel too?? Buttons are so cheap I'd get proper round ones like on the original Neo Geo to replace those. Concave, convex, illuminated, not illuminated, anything would be more player friendly. Then you can use one of those square ones to replace the burned out button on the front of the machine where the shape doesn't matter.
