Author Topic: Power supply proper hookup question  (Read 4885 times)
Trebeck
  • "The Arcade" - Build #4
« on: May 15, 2021, 10:47:49 am »
Hey all,
I wanted to double check that I have this correct as I dont feel like starting a fire today :)
If you guys could have a look I would be very very grateful.
L = Live/White
N = Neutral/Black
(-) = Ground/Green
COM = neutral/black
COM = neutral/black
+V = Live/Red
+V = Live/Red
+V ADJ = for adjusting voltage
Trebeck
  • Last login:Today at 11:51:09 am
Re: Power supply proper hookup question
« Reply #1 on: May 15, 2021, 11:03:04 am »
You've got the AC Live and Neutral wires reversed.
L = Live/White Black
N = Neutral/Black White
The "upside-down christmas tree" 3rd connection (Green wire) from your AC power cord is Ground, often referred to as Frame Ground.
- Ground metal-frame parts, trackball housing, coin door, etc. here.
(*** Exception - If you have a monitor with an isolation transformer, DO NOT ground it here. ***)
The 4th and 5th COM (common) are grounds (-) for DC power. (Black wires)
The 6th and 7th V+ (positive voltage) are the operating voltages (+) for DC power. (Red wires)
« Last Edit: May 15, 2021, 11:24:33 am by PL1 »
Trebeck
« Reply #2 on: May 15, 2021, 01:42:08 pm »
I love this forum.  Thanks so much for the help Scott!
« Reply #3 on: May 15, 2021, 01:53:44 pm »
Glad to assist.   :cheers:
Trebeck
« Reply #4 on: May 17, 2021, 08:38:36 am »
It worked and nothing exploded!
Drnick
  • Plodding Through Life
« Reply #5 on: May 24, 2021, 01:18:11 pm »
Is that for when you get the high score on your favourite game, sirens and lights go off :)
Trebeck
« Reply #6 on: June 03, 2021, 07:06:22 pm »
Yah and when you win at street fighter.  They are not automatic but that would include more code than I could handle.  :cheers:
