Author Topic: Mounting Sanwa JLF-TP-8YT from the Bottom without Routing?  (Read 1398 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: March 04, 2021, 10:08:33 am »
I'm using 3/4" plywood, and my thought was to bottom mount the Sanwa JLF-TP-8YT without routing - I know, I know, with a 34mm joystick shaft it'll leave just 15mm when mounted, so it'll be less than 10-15mm below the 'standard/normal'.  However, thinking back to the Galaga Cab, the joystick also has a very short shaft....so thinking maybe I could get away mounting this way?  What is the disadvantage of having a joystick shaft shorter than the norm?
Re: Mounting Sanwa JLF-TP-8YT from the Bottom without Routing?
« Reply #1 on: March 04, 2021, 10:43:42 am »
Just personal preference.
  • Last login:February 27, 2026, 02:29:01 pm
« Reply #2 on: March 04, 2021, 11:55:01 am »
As men we try to make the shaft look longer not shorter.
You might run into the stick hitting the edges of the hole.
« Reply #3 on: March 04, 2021, 12:28:23 pm »
Both great points.  Make sure your shaft clears the hole or it will limit everyone's fun.
