Author Topic: joystick no up / down  (Read 2302 times)
spisi
  • Last login:December 07, 2024, 06:45:34 am
« on: February 06, 2021, 01:44:52 pm »
I have a working joystick (tested with antimicro) but MAME doesn't recognize up / down, but recognizes left / right. Any ideas what would cause this?
Just tested it on another PC, same issue.....Antimicro sees left / right as axis one, no problems there.  Antimicro sees up / down as axis 2, MAME is not seeing this...
Also, works in Windows settings...Hmmm.....
« Last Edit: February 06, 2021, 02:23:34 pm by spisi »
  • Last login:Today at 04:43:40 am
Re: joystick no up / down
« Reply #1 on: February 06, 2021, 03:14:50 pm »
Wait, is this an analog (potentiometer) joystick with 1 input per axis in MAME or a microswitch joystick with 2 inputs per axis in MAME?
spisi
« Reply #2 on: February 06, 2021, 03:49:57 pm »
Microswitch
« Reply #3 on: February 06, 2021, 04:10:40 pm »
In what MAME game and to which inputs are you trying to map Up and Down?
- For example, Donkey Kong: P1 Up and P1 Down
spisi
« Reply #4 on: February 06, 2021, 04:16:15 pm »
I've tried Ms. Pacman and Pacman with same results
« Reply #5 on: February 06, 2021, 04:47:30 pm »
Are you saying that "Up" (the default setting) is not mapped to the "P1 Up" input and you're unable to remap the input or are you saying that pressing up --straight up, not an accidental diagonal-- on the joystick is not registering during gameplay?
« Reply #6 on: February 06, 2021, 06:23:26 pm »
Pretty sure a multimeter will solve the problem.  >:D
spisi
« Reply #7 on: February 06, 2021, 07:27:13 pm »
A fresh install of MAME and it works... :dunno
« Reply #8 on: February 07, 2021, 07:30:42 am »
Yeah, just mentioning a multimeter in Spisi's thread scared the gremlins out of his system.   :lol
spisi
« Reply #9 on: February 07, 2021, 11:05:22 am »
When all else fail....grab the multimeter  ;D I think I had been messing with the mame.ini file when it comes to the joystick mapping, that was most likely the culprit
