Author Topic: Tutorial: How To Get a Supermodel Multiplayer Network Running  (Read 3371 times)
MrThunderwing
  • Last login:January 17, 2026, 07:15:09 am
I've put together a little tutorial on how to get a multiplayer network running in supermodel for anyone who's not sure about what to do.
buttersoft
  • Last login:Today at 04:54:25 am
  • Is running at 15kHz
Re: Tutorial: How To Get a Supermodel Multiplayer Network Running
« Reply #1 on: July 30, 2020, 07:43:41 pm »
Thank you! I'd be using instances on separate PCs, is that much different?
Is this worth it yet? Things have been optimised?
« Last Edit: July 30, 2020, 07:45:38 pm by buttersoft »
MrThunderwing
« Reply #2 on: July 31, 2020, 03:49:26 am »
I do talk about how to get a multi-system LAN working at the end. It's the actual network itself that's causing the slowdown, much more so than the need for the - no-threads command. I haven't actually tried a LAN, but apparently it's much slower than a single system network, and runs at about 11fps on each PC its been reported.
buttersoft
« Reply #3 on: July 31, 2020, 06:45:59 am »
My hi-speed fribe-ring is in for service this week :(
MrThunderwing
« Reply #4 on: July 31, 2020, 12:56:52 pm »
Even a high speed connection won't make a difference with a LAN I'm afraid. The actual network itself is faulty, one of the Supermodel developers explained it as: "The current network code is waiting a full frame to receive data. Either the data is being received in the wrong place or it's missing some irq. It should be quite possible to run 16 players on a Lan with minimal latency."
With the single system running at around 25 - 30fps though, games are playable. I got some friends over awhile back to record some games and then edited them into the correct speed during video rendering.
« Last Edit: July 31, 2020, 01:01:48 pm by MrThunderwing »
