Author Topic: Hinges for Midway cocktail?  (Read 1348 times)
Osirus23
« on: June 23, 2020, 03:07:16 pm »
I have a Pacman cocktail I built from scratch, but the hinges I used are junk. I need to replace them with something that can actually be used. Does anyone know where to get something good for them? The original Pacman cocktails used a piano hinge, which seems awful because you're screwing into plywood parallel to the plys which can't be strong. I believe the Ms. Pacman cabs changed it to use some kind of offset hinges that used bolts going through the panels instead, but I cannot find them anywhere.
SLICK19
  • Last login:September 08, 2024, 09:33:50 pm
  • GET LOST PUNK !
Re: Hinges for Midway cocktail?
« Reply #1 on: June 27, 2020, 12:41:36 pm »
I am in the process of getting ready to build a cocktail cab myself and have been looking for the same thing. Anyway, this is the closest thing I have found after looking at tons of hinges. Maybe this will work.
https://www.hollandcomputers.com/store/pc/Arcade-Game-and-pinball-Cabinet-Hinge-10-cm-4-inch-for-use-with-0-5-inch-board-or-melamine-p6691.htm
