Author Topic: Flynn's Arcade Build - Story/Writeup/Etc...  (Read 4731 times)
ffingers
  • Last login:February 19, 2020, 10:57:01 am
« on: February 19, 2020, 10:17:58 am »
Well....where do I even begin. I guess I'll start with a picture. This is Flynn's Arcade (I know...I know) :dunno It's about 95% complete. Still have a few things to finish but it's mostly done. I have been a part of BYOAC for probably 10+ years but only recently did I actually start my build. I have learned SO much from this forum and it was the start of this journey for me. I figured I needed to give back in some way and go through what I did, what I did wrong (spolier:a lot), what I used, why I did it, the process etc. I know build threads help me get ideas and helped direct me to where I ended up.
This will be a LOT of writing from me and I'm going to do my best to break it down into sections and make a menu etc so you can ignore the backstory if you want and jump straight to a certain section. I only ask that you bear with me as I type all this up as it will likely take at minimum a week or so to get all this info together.
With that being said, here are a few pictures to show where it's at and what I'll be talking about.
Video of the frontend in action:
« Last Edit: February 19, 2020, 10:23:02 am by ffingers »
Flynn's Arcade - it's HERE! Build and writeup!
ffingers
Re: Flynn's Arcade Build - Story/Writeup/Etc...
« Reply #1 on: February 19, 2020, 10:26:50 am »
[Reserved for future write-up]
ffingers
« Reply #2 on: February 19, 2020, 10:27:05 am »
ffingers
« Reply #3 on: February 19, 2020, 10:27:19 am »
ffingers
« Reply #4 on: February 19, 2020, 10:27:28 am »
ffingers
« Reply #5 on: February 19, 2020, 10:27:43 am »
ffingers
« Reply #6 on: February 19, 2020, 10:28:02 am »
« Reply #7 on: February 19, 2020, 01:52:56 pm »
That bezel looks like it belongs on a CRT.  Did you make it yourself?  I like the look.
  • Last login:Today at 02:01:07 pm
« Reply #8 on: February 20, 2020, 09:24:38 am »
Looks like a really well-made cab.  Are you the one that came up with that CP shape?  I see it all over the place so people must really like it.
  • Last login:May 19, 2026, 11:21:47 am
« Reply #9 on: February 20, 2020, 09:57:01 am »
No, Jarrett designed it but never actually built it.
  • Last login:Today at 10:49:41 am
« Reply #10 on: February 20, 2020, 10:26:04 am »
The Klingons use that CP design in ritual combat.
