Author Topic: Need help with construction  (Read 5399 times)
ballboff
  • Last login:July 22, 2024, 02:25:17 am
« on: October 24, 2019, 02:45:19 am »
So i've got a icade jr, which i've ripped apart.  I've also got a 3.5 inch screen that uses the gpio of the pi.  I've also got a picade hat.  I want to connect all 3 together and I'm not sure how.  The icade jr has controls which I want to use and I was wondering if it's worth it, and if it's easy to wire them up to the picade.  The pi i'm trying to use is a pi A+ i think, the first gen.  Now I know you're gonna say i'd be better off with a pi zero, but I just think that would take too much configuration.  Will I need to solder all the controls by hand and then attach wires that connect to my picade hat?  I seem to be struggling with space too, i've seen mobile solutions knocking about, but do these all use zero boards?
https://shop.pimoroni.com/products/picade-x-hat-usb-c
https://www.amazon.co.uk/iCade-Arcade-Cabinet-iPhone-ThinkGeek-Red/dp/B0083T1M3E
Drnick
  • Plodding Through Life
Re: Need help with construction
« Reply #1 on: October 24, 2019, 08:12:20 am »
I have one of these, they are tiny :) OK you will need to strip down and get at the bottom of the controls, On mine it had very small wires going to a control board. Cut all those wires at the board end, Then connect those up to wire and pin blocks for the pi hat. (Looks like you can purchase a picade wiring loom which should have everything you need on that front).   The main problem will be one of room to fit everything in the Icade,   Personally I would take the controls out of the Icade and build something the right size to fit pi/hat/screen and controls comfortably.
See the following for someone that did same with the larger Icade. Theory is all still the same.
https://www.instructables.com/id/Bartop-Mini-Retro-Arcade-Raspberry-Pi-and-Customis/
ballboff
« Reply #2 on: October 25, 2019, 09:06:50 am »
Cheers mate. Yeah i've got one of those too, which I did exactly that with.  That's what gave me the idea of doing it with a jr.  I've opted for stripping out the controls like you've said and i'm going to use a brand new set of tactile buttons that I should be able to just hook straight up to my picade hat like you said.  Appreciated.
