Author Topic: IPAC-4 Shifted Keys issue  (Read 2372 times)
nipsmg
  • Last login:January 20, 2026, 10:46:56 am
  • ROONEY!! ERRGH!!
    • Arcadia
« on: May 21, 2019, 12:54:18 pm »
I've got one of the older Ipac 4 board with the PS/2 connectors on it.  I'm using it over usb with the supplied cable.
The board works perfectly except for the shifted keys.  When I assign a p1/p2 shift key to, say, P2 start and program the board, the following happens:
1. The start key now only registers when I let go of the button
2. The "left mouse" action I applied to the "P1 Sw1 shifted" key does not fire when I click P1SW1 while holding P2Start.
Does anyone have any feedback / suggestions?
  • Last login:Today at 03:53:37 pm
Re: IPAC-4 Shifted Keys issue
« Reply #1 on: May 21, 2019, 01:40:58 pm »
That's normal operation for shifted functions.
When you press Start (shift), the IPac doesn't know if you want to do Start or a shifted function.
- If a button with a shifted function is pressed before you release Start, it sends the shifted function keystroke immediately.
- If no button with a shifted function is pressed before you release Start, it sends the Start keystroke.
KenToad
  • Last login:Yesterday at 07:26:35 pm
  • Flap Flap Flap
« Reply #2 on: May 21, 2019, 02:10:10 pm »
You should be getting that left mouse press while holding down the shift key.
I would test a normal letter key as a shifted key first, so that you can confirm it works in a blank document before trying mouse functions.
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #3 on: May 21, 2019, 03:54:08 pm »
ok, so the a letter key works when assigned as a shifted function,  but the mouse button assignments don't work :-/
