Author Topic: Restarting what I didn't finish ages ago  (Read 2686 times)
sleong
  • Last login:December 26, 2021, 04:11:56 pm
  • Novice builder of Arcade Machines
« on: April 16, 2019, 04:04:11 pm »
Hello everyone,
I've been out of groove to building a cabinet and finally after doing some spring cleaning I found some parts that I have already started and just been sitting in the basement.
Its be a waste to just get rid of it and the time I already spent on cutting some of the parts and research in building a cab so. . . . here I am going to try to finish what I started a while ago.
Plus the Mrs. gave me the ok to finish it (can't say no to that now) and build another if I want!
So I want to find out when routing the T-molding slot is a 1/4" shank going to be enough or is a 1/2" shank better?  This is still one tool I have not gotten yet and looking to getting one soon so that I can get the T-molding slot cut in.
What is another good way to drill out the holes for the buttons?  I don't have a drill press but do have a drill but I'm not that good at making straight 90 degree cuts!  I have the spade bits and forstner bits and the hole saw bits.  Which is better to use for this application?
So many more questions but a few at a time!
Thanks in advance.
Steve
Re: Restarting what I didn't finish ages ago
« Reply #1 on: April 16, 2019, 04:21:25 pm »
Bit of advice, pre-drill guide holes for the Forstner bits and they’ll work a lot better for you.
  • Last login:Yesterday at 09:53:21 pm
« Reply #2 on: April 16, 2019, 05:39:15 pm »
Of those three bits, the forstner bit is probably the best choice.
A spoiler board underneath while drilling is also a good idea to prevent blowouts.
You may want to look into a drill guide like this one or this one to keep the drill vertical.
  • Last login:January 02, 2026, 07:00:04 pm
« Reply #3 on: April 16, 2019, 11:31:28 pm »
I like to drill a pilot hole first for alignment and then drill from both sides... seems to work well.
Drnick
  • Plodding Through Life
« Reply #4 on: April 17, 2019, 08:08:20 am »
For the slot cutter 1/4" shank will be fine, but if the 1/2" is available and isn't twice the price then I would go with that :)
  • Last login:Yesterday at 01:17:13 pm
« Reply #5 on: April 17, 2019, 09:54:28 am »
1/2 inch shank is always better. The forces at play with a router are terrifying enough as it is.  A beefier bit cuts the risk of flying shrapnel. You also want to use the correct router speed. That is often overlooked. You want to keep the rim speed under control. A 2 inch diameter bit should generally be under 18,000 rpms. A 3 inch bit should be under 14,000 rpms. The reduced rpms help keep the rim speed under control. A half inch diameter bit at 20,000+ rpms will have a rim speed near 40mph. A 3 inch bit at the same rpms will have a rim speed over 200 mph. A .25 inch shank is more prone to failure at those high speeds when you crash a hunk of wood into it.
« Reply #6 on: April 17, 2019, 01:50:12 pm »
What he said.  I've seen one of those break before and it's like watching a ninja star thrown by the terminator.... or a pipe bomb depending upon how it breaks.
