Author Topic: Sega Model 2 UI  (Read 136234 times)
tangodownNZ
  • Last login:September 29, 2025, 05:07:04 am
Re: Sega Model 2 UI
« Reply #80 on: January 25, 2022, 10:47:51 pm »
Hey Nuexzz,
Sorry I forgot to tell you. You can stick that .ini file right up your  :censored:
Now you guys watch how quickly I get a response. As soon as I say something like that they respond straight away. But when I say please and wait patiently they don't respond. I don't want help from ---punks--- like this. They can stick it.
isamu
  • Last login:February 19, 2026, 01:09:24 pm
Re: Sega Model 2 UI
« Reply #81 on: January 26, 2022, 12:25:57 pm »
Hey Nuexzz,
buttersoft
  • Last login:Today at 06:01:46 pm
  • Is running at 15kHz
Re: Sega Model 2 UI
« Reply #82 on: January 26, 2022, 04:24:59 pm »
tangodownNZ
Re: Sega Model 2 UI
« Reply #83 on: January 26, 2022, 08:54:49 pm »
As predicted, see how fast the replies came  :applaud:
Next thing Nuexzz will say he was just about to get back to me too, but now I've blown it  :laugh2:
I'm not mad. I just think it's very rude and unnecessary what he done. If you can't do it, just say you can't do it, or its going to take 2 -3 months because he's so busy.
Anyway, I don't care anymore I'm over it.
buttersoft
Re: Sega Model 2 UI
« Reply #84 on: January 26, 2022, 11:49:55 pm »
I bet you're a delight at parties.
Nuexzz
  • Last login:October 01, 2023, 01:26:58 am
Re: Sega Model 2 UI
« Reply #85 on: January 30, 2022, 03:57:41 am »
I am rude? or you a clown who thinks I'm an employee of yours? Not for all the gold in the world would I help him... Is that clear? okay bye
« Last Edit: January 30, 2022, 04:08:04 am by Nuexzz »
Nuexzz
Re: Sega Model 2 UI
« Reply #86 on: January 30, 2022, 04:04:35 am »
I can't believe they are so ignorant that they can manipulate an emulator with (ini) options which were not implemented, but hey these guys are the new generation who grew up using a smartphone without knowing what it's like to use a Windows XP" poor children" :blah:
Nuexzz
Re: Sega Model 2 UI
« Reply #87 on: January 30, 2022, 04:17:16 am »
in the model2ui user interface the requested options are available, now if the antivirus says that it is doubtful. don't be fearful If you are scared, it will be a big problem for you. This life is not for the scared! it's just one! he has :laugh2:
tangodownNZ
Re: Sega Model 2 UI
« Reply #88 on: April 09, 2022, 06:21:29 am »
@Nuexzz The issue I had with your UI was my antivirus kept quarantine the .dll files. It is sorted now.
Thank you, your UI does allow a maximized window at 1080p. Got there in the end.
Daytona hacks allows infinite time. Is there a way to run the hack application through your UI to allow infinite time? I can't use the hack because it doesn't allow two instances of the same game with maximized windows at 1080p
« Last Edit: April 12, 2022, 03:07:53 am by tangodownNZ »
ThatGuyNamedAA
  • Last login:May 23, 2022, 10:56:45 pm
Re: Sega Model 2 UI/ Xbox One Controller
« Reply #89 on: April 25, 2022, 08:07:25 pm »
Hello everyone, it really bothers me to have to do many steps to configure my favorite game, then I started to add some features for Daytona and started adding functions until I finished adding all the games.
Keep in mind that if you have errors is because I'm not a programmer (just curious) which I consider a Hobby, I have no trouble with the aggregates I plan to do.
in a few words, I publish it to not keep it for me, as I did with many things.
I have an important question.
Can I use my Xbox One controller as an alternative to an Xbox 360 controller? And if so, does it have to be wired or can it be wireless?
Please answer  :)
Update: I learned that you can, but it is best that you either use a wired controller or use a USB to make it wired.  :cheers:
I'm still looking into wireless play.
« Last Edit: May 15, 2022, 10:34:46 pm by ThatGuyNamedAA »
Yolo_Swaggins
  • Last login:September 06, 2025, 07:30:41 pm
  • Autistic and retro for life
Re: Sega Model 2 UI
« Reply #90 on: July 08, 2022, 05:49:53 am »
Hi thanks for the patch, i got widescreen to work on virtua cop 1 & 2 but the bullets still only can be shot within the 4:3 size window, if i try and shoot on the outer edge of the screen the bullets wont reach that far although the crosshair will be in that area it's like the bullets are locked into the original 4:3. is there a fix for that or it's just the way it is?
Nuexzz
Re: Sega Model 2 UI
« Reply #91 on: July 09, 2022, 01:23:10 am »
Hi, I had no idea about this error. I'm going to look at it in a month or so to be honest, I don't have a pc yet
Nuexzz
Re: Sega Model 2 UI
« Reply #92 on: July 09, 2022, 01:27:59 am »
could try modifying some of these for the time being.
[Model2_SetWideScreen(1)
Model2_SetStretchBLow(1)
Model2_SetStretchBHigh(1)]
nonosto
  • Last login:November 10, 2023, 01:37:29 am
Re: Sega Model 2 UI
« Reply #93 on: July 12, 2022, 05:26:35 am »
is it possible to patch original eeprom for widescreen for example sega rally ?
Nuexzz
Re: Sega Model 2 UI
« Reply #94 on: July 21, 2022, 01:48:21 am »
hardware i cant help you  :dunno
MydknyteStyrm
  • Last login:March 20, 2024, 12:19:41 pm
  • Makeup FX Gamer
Re: Sega Model 2 UI
« Reply #95 on: July 25, 2022, 08:40:02 am »
Thank you for this. The widescreen looks fantastic. My only issue is that I can’t get DemulShooter to play nice with your version of the emulator.exe. No matter what I won’t get two guns. Works fine on the 1.1a. Are they different emulators in a sense of the coding you wrote for the widescreen hacks, or are they the same? The INI for both yours and the 1.1 are relatively the same. Does anyone have DemulShooter working with this version? Thanks in advance.
scju
  • Last login:November 01, 2022, 01:59:05 am
Re: Sega Model 2 UI
« Reply #96 on: August 16, 2022, 01:46:18 am »
To be honest, the same question for me.  ::)
I hope that one day I can use higher windowed mode resolutions for two or more Model 2 applications on one screen, playing Daytona USA with my friend(s).  :)
I mean, now the game is like this:
If you don't mind, Nuexzz, could you please help to adapt resolutions to window sizes?  :)
« Last Edit: August 16, 2022, 02:28:05 am by scju »
Nuexzz
Re: Sega Model 2 UI
« Reply #97 on: August 18, 2022, 01:37:15 am »
I can't help you at the moment, sorry
scju
Re: Sega Model 2 UI
« Reply #98 on: September 13, 2022, 10:48:18 pm »
Take your time.  :)
connormmii
  • Last login:August 04, 2025, 04:19:00 am
Re: Sega Model 2 UI
« Reply #99 on: September 22, 2022, 04:14:16 pm »
Where is the link for the latest version of the UI? Im not sure I'm running the latest version
moonitor
  • Last login:May 10, 2023, 05:02:09 pm
Re: Sega Model 2 UI
« Reply #100 on: May 10, 2023, 05:02:54 pm »
hello to everyone, I have a problem with Sega Model 3 UI -r886, when I double click it to open an error occurs:
"The file LibreriaIconos.dll is missing".
Do you know how to solve it ?
SegaFan22
  • Last login:July 06, 2024, 04:02:23 am
  • Insert Coin
Re: Sega Model 2 UI
« Reply #101 on: May 13, 2023, 02:23:59 am »
Check the title, buddy. This discussion is about the Model 2, not 3. Open a new one or ask elsewhere  :dunno
Monza
  • Last login:September 27, 2023, 12:39:27 am
Re: Sega Model 2 UI
« Reply #102 on: September 05, 2023, 07:40:06 am »
Link is broken?
Aussiejzx
  • Last login:January 05, 2026, 12:07:39 am
Re: Sega Model 2 UI
« Reply #103 on: November 21, 2024, 03:23:19 am »
Damn this thread was a rollercoaster! Love the work you'd put in on it Nuexzz!
Does anyone have the latest copy of the UI they could upload somewhere? I couldn't find it anywhere else online sadly.
Monkee
  • Last login:June 08, 2025, 10:45:43 am
Re: Sega Model 2 UI
« Reply #104 on: March 24, 2025, 05:59:01 pm »
It's been a while but I'd also be happy to put my hands on the UI built by Nuexzz.  :notworthy:
TwilightHitman
  • Last login:April 21, 2025, 04:34:35 pm
Re: Sega Model 2 UI
« Reply #105 on: April 21, 2025, 03:16:25 pm »
That link in the 1st post appears to be dead...so I ended getting it from this site: http://www.emu-france.com/emulateurs/6-arcades/68-nebula-m2emu-crystalemu-cps3emu/7655-sega-model-2-ui/  (3.3MB). Whenever I attempt to run the Sega Modul 2UI.exe I get an error stating: The file Print.dll is missing. Does anyone have any suggestions on how to fix this? I can run emulator.exe fine, but I really want to open the UI so that I can change the resolution for Windowed Daytona to 1920x1080. If I attempt to run Fullscreen mode, my OBS can't capture the window anymore.
