Author Topic: GroovyMAME 0.205 on Windows XP  (Read 4010 times)
Gandalf68
  • Last login:March 27, 2019, 11:14:05 am
  • Arcade is the best thing after sex !
« on: February 19, 2019, 01:59:47 pm »
Hello everyone !
I have been using GroovyMAME 0.164 on a computer with Windows XP 64bits for several years and i finally decided to upgrade to 0.205.
But when i try to start GroovyMAME 0.205, i get this message :
"The procedure entry point k32enumprocessmodules could not be located in the dynamic link library KERNEL32.dll"
I have checked in my SysWOW64 directory, and there is a KERNEL32.dll file.
I have the Service Pack 2 installed -> would installing the Service Pack 3 solve the problem ?
Or would someone have another solution ?
Thanks in advance for you advices
Drnick
  • Plodding Through Life
Re: GroovyMAME 0.205 on Windows XP
« Reply #1 on: February 19, 2019, 03:43:29 pm »
Is the kernel32.dll file also in windows\system32 folder? (I also assume that you did get the xp version) I put that bit in brackets because its basically the same error that o365 gave when I tried to install on a vista machine recently, turned out its trying to call a command that wasn't supported before Windows 7 :)
  • Online Online
  • Last login:Today at 10:51:11 am
« Reply #2 on: February 19, 2019, 04:04:47 pm »
I'd say this might be due to the upgrade of bgfx that happened on v0.205. I wonder if anyone else has tested 205 or 206 on WinXP 64.
BTW, don't try anything silly like copying or downloading different versions of kernell32.dll, it won't work and you may break your OS installation.
Gandalf68
« Reply #3 on: February 19, 2019, 04:26:13 pm »
Yes, but i'm not sure if it's the XP version of the file -> i wasn't even aware that there was an XP version
Thanks for the advice ! I'm glad you told me that because i was also considering trying that !
Drnick
« Reply #4 on: February 20, 2019, 08:08:36 am »
Sorry I meant XP version of Groovymame, As I see that there are 2 versions 1 is for 7-8-10 and the other for XP.
And very good advice on the  don't download DLL's and start replacing them.
Could be worth trying version 0.204 and seeing  if that works OK?
Gandalf68
« Reply #5 on: February 20, 2019, 01:49:03 pm »
That's exactly what i'm intend to do  ;)
I just have to find the time to do it, and then i'll post the results here
Gandalf68
« Reply #6 on: February 20, 2019, 03:59:57 pm »
Ok i tested it with GroovyMAME 0.204 and it worked, no error message  ;)
  • Online Online
« Reply #7 on: February 21, 2019, 04:18:51 am »
Then it's almost sure it's because of the BGFX update. Please test this with baseline MAME (v.206).
Gandalf68
« Reply #8 on: February 21, 2019, 11:16:49 am »
OK i just tested MAME 0.206 and it did not work -> i get the Kernell32 message
