Author Topic: Sega Rad Mobile Help  (Read 6727 times)
rawbe
  • Last login:June 17, 2025, 05:54:46 pm
« on: January 29, 2019, 08:07:16 am »
Hello-
I recently bought Sega's Rad Mobile Deluxe and it needs some work. No power. Is this pic the power supply? Can anyone tell by the pic if it's fixable?
Can you still buy this game’s power supply? Could a standard arcade power supply work?
Thanks,
Robbie
baritonomarchetto
  • Last login:Today at 02:19:44 am
Re: Sega Rad Mobile Help
« Reply #1 on: January 30, 2019, 12:45:49 am »
It's not possible to "see" if the PSU (or any other electronic device) is not working (sometimes it is really, but those are rare cases). The easyest thing to do is test it. You need the schematics for the psu and a 10 bucks multimeter.
killallhumans
  • Last login:May 21, 2021, 06:57:37 pm
  • What does this red button do?
« Reply #2 on: January 30, 2019, 02:56:15 am »
Sadly, i've seen this all too often...   and it looks like moisture damage.
Dark spots are where things shorted out. So, what now? Glad you asked.
It all depends on, if you want to keep everything stock, or if you just want it working again.
Answer to both is replace power supply.
(1) Stock: Find part number and search on google.
(2) Make it better than new:
STOP! - - - !!! UNPLUG POWER FROM WALL FIRST !!! - - -
Locking plug with 3 wires is your line input 120-240 volts, 50-60 Hz. Center wire is ground.
Red and black wires, cooling fan, maybe? Please, see where they go.
This only leaves your small plug with ~7 wires. Now you may need some help. One of those
wires turns supply on. Some go to ground rail. Others give regulated voltage(s) to system.
Ok, i searched, system name only, with not much luck. Start by carefully removing bad supply.
Look for any stickers or writing on outside case. Snap some pictures of anything you find.
Post them here, and i will see what information i can dig up. Fingers crossed, pin-out of plug.
Please, for your sake, don't start poking wires in holes, or try to hook up an ATX power supply,
without first learning what each wire is for, and voltage requirements on them.
Come back soon, and i'd be glad help.
Good luck.
- David C
Almost missed blue and white wires soldered in lower right. Follow them too, to where?
« Last Edit: January 30, 2019, 03:18:24 am by killallhumans »
Auto•It 3 fixes everything.
Game loading, lights, sounds,
control mapping, screen rotation...
Compile scripts to EXEs and drop them
into your arcade Frontend.
killallhumans
« Last Edit: January 30, 2019, 04:16:43 am by killallhumans »
rawbe
« Reply #4 on: January 30, 2019, 08:27:15 pm »
Thank you for the info! I have the game working now but the motor driver sparks and burns when plugged in. I am all for finding an alternative motor driver but I am not sure that is possible. I am hunting down transistors and caps now to see if I can repair.
Does anyone here rebuild this type of motor drivers?
killallhumans
« Reply #5 on: February 04, 2019, 06:26:20 am »
Looks like it's been done before.
With snails!   ;D
Start with cleaning 400-5117Y PCB very well.
Then check that motor is not worn out, as this will cause it to draw too
much current from driver board.
NOTE: Your mains voltage may not match their system.
Set your voltage taps, according to pdf documentation, for your country.
However, 12 volt output should be the same, when set correctly.
[French]
https://www.gamoover.net/Forums/index.php?topic=28406.0
[English] ; via Google translate.
https://translate.google.com/translate?hl=en&tab=wT&sl=auto&tl=en&u=https%3A%2F%2Fwww.gamoover.net%2FForums%2Findex.php%3Ftopic%3D28406.0
You have an exciting project.
Only by working on this arcade system, as whole, would anyone fully
understand what problems it's having.
Sorry i can't be there to dig in with you.
Good luck.
- David C
« Last Edit: February 25, 2019, 03:39:44 pm by killallhumans »
rawbe
« Reply #6 on: February 12, 2019, 05:06:13 pm »
Thanks David!! It’s on!!
Dave11674
  • Last login:December 29, 2022, 01:32:34 pm
« Reply #7 on: April 14, 2020, 08:25:39 am »
Hi
Did you manage to get anything done with your driver pcb
I have the same machine
With the same problem
Dave
Dave11674
« Reply #8 on: April 14, 2020, 11:25:52 am »
Looking closer and testing the transistors and diodes
Lots are blown/short/open circuit
And tracks adjoining are also burnt out
Going to be a bit of work this one :-/
Could do with the schematics for this motor board if they sre about
Dave
