Author Topic: Retroarch - Super Resolutions  (Read 2621 times)
philexile
  • Last login:October 30, 2022, 03:45:01 pm
  • I want to build my a GroovyMame PC!
« on: January 09, 2019, 08:50:32 am »
Hello,
I recently setup GroovyMame with super resolutions and I was hoping to try out Retroarch as well to play some consoles – NES, PSX, Super Nintendo, etc.
I was able to get NES running correctly, but Super Nintendo didn't seem to work with the Super Resolutions that were installed. The screen was compressed vertically at the top of the screen.
Is there a way to get the Retroarch cores working with Super Resolutions or should I install additional modelines?
Thank you!
Arroyo
  • Last login:November 26, 2025, 09:34:25 pm
  • Budgets are boring
Re: Retroarch - Super Resolutions
« Reply #1 on: January 09, 2019, 07:21:47 pm »
philexile
« Reply #2 on: January 09, 2019, 10:52:36 pm »
It didn't really help me. The infuriating thing is that when Retroarch boots, it's using the correct modeline resulting in a 240p image. When I launch a game, it switches back to a 720p modeline that I use for my desktop.
I've been through the config file a few times now and I'm stumped. Any ideas?
Thank you
Arroyo
« Reply #3 on: January 09, 2019, 10:57:41 pm »
Thank you
Retro arch can be a bear in that the settings can be global or “core”, meaning it allows you to set a general setting or in a “core” or system (i.e. Super Nintendo) basis.  It’s possible your global setting is bringing in the 240p and your core setting is overriding it with a desktop resolution?  You may want I start over in the Retroarch install and start fresh unless you feel confidant in the per “core” and global settings differences.  I’d start global get what you want, and then if you aren’t satisfied with something on a system edit it at the core level.
philexile
« Reply #4 on: January 09, 2019, 11:27:38 pm »
I was able to fix this issue by turning off "crop overscan" which seems to be the default. Now the cores adhere to the super resolution.
Scratch that. While this seems to work with the NES cores (BNES and Nestopia), it has stopped working for the BSNES core. Unsure why.
I am able to get it to work with BSNES, but it has to be the first game launched. If I select another rom, it will boot into 31 khz mode. It's very odd. Hopefully this is an incorrect setting?
« Last Edit: January 10, 2019, 12:10:04 am by philexile »
