Author Topic: TurboTwist Push-Pull Arcade Spinner Control  (Read 3210 times)
pixelpalace
  • Last login:December 25, 2022, 09:37:13 pm
    • Pixel Palace Arcade and Bar
« on: January 06, 2019, 11:00:17 pm »
Anyone ever config GroovygameGear's TurboTwist Push-Pull Arcade Spinner Control? I am using two of them. One is a master and the other a slave. There is just no documentation though.
pixelpalace
Re: TurboTwist Push-Pull Arcade Spinner Control
« Reply #1 on: January 08, 2019, 06:36:33 pm »
I got the spinner to work but cant figure out how to get the push-pull to work. Any suggestions?
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
Mr. Peabody
  • Last login:November 11, 2025, 07:08:52 pm
« Reply #3 on: January 10, 2019, 01:48:24 am »
Up/down should be the equivalent of mouse buttons. Also, Randy includes printed diagrams with his products.
pixelpalace
« Reply #4 on: January 12, 2019, 10:55:31 pm »
I got the push/pull too work but now cant figure out how to hook up the 2nd spinner without using its own dedicated board. I was told I could set this up as a master and slave.
Mr. Peabody
« Reply #5 on: January 16, 2019, 07:24:16 pm »
There should be a connector cable to slave one to the other.
pixelpalace
« Reply #6 on: January 17, 2019, 03:05:20 pm »
After careful review, it looks like I ordered two masters. BUT i did get the push/pull to work. However, a new issue popped. Player 1 works beautifully but when I add player 2, the spinner controls player 1 as well. The push/pull works independatly for each player but i cant figure out why player 2 is controlling player 1.  They are are on separate boards and separate USB inputs.
Originally, in advmame, I had :
input_map[p1_dialx] mouse[0,x] mouse[1,x] mouse[2,x] mouse[3,x]
Then for troubleshooting, I added :
input_map[p2_dialx] mouse[0,y] mouse[1,y] mouse[2,y] mouse[3,y]
I even tried :
input_map[p2_dialx] mouse[0,x] mouse[1,x] mouse[2,x] mouse[3,x]
it makes no sense. I had them both working. Turned off machine, and then is started this nonsense.
tommyinajar
« Reply #7 on: August 16, 2019, 02:36:57 pm »
Did you ever get it working?
Mr. Peabody
« Reply #8 on: August 20, 2019, 01:34:51 am »
Yeah. You should test in baseline, then test in another build.
