Author Topic: Need help: I think sync issue w/ groovymame and K7000  (Read 4432 times)
nipsmg
  • Last login:December 02, 2025, 01:18:04 pm
  • ROONEY!! ERRGH!!
    • Arcadia
« on: January 04, 2019, 02:23:08 pm »
So.. this is a crosspost from the monitor forum... but i know the monitor works (because it's beautiful hooked up to my tekken 3 PCB)..
I know my Groovymame setup works, because it's beautiful hooked up to my RGB modded 27-KV300 Trinitron..
So I'm thinking this might be a groovymame/vmmaker issue. Here's what's happening with my K7000a I just repaired:
So I wired up a vga breakout cable and hooked it up.
I’m getting the following running TMNT forcing -resolution 320x240 out of groovymame.
This is with hsync and vsync both wires up to the hsync- and vsync- terminals on the chassis respectively.  Any suggestions?
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
Re: Need help: I think sync issue w/ groovymame and K7000
« Reply #1 on: January 04, 2019, 03:53:32 pm »
I read a post form 2016 stating with 2.0 onward, sync is always positive now... should I rewire the harness, or is there a way to adjust it in vmmaker or something to output negative sync?
  • Last login:Today at 03:21:25 am
« Reply #2 on: January 04, 2019, 04:14:58 pm »
Nope, that was a bug from the early 2.0 releases that was fixed very soon, you can check the change logs. Sync polarities are correct, according to what's specified by VMMaker, this is superconfirmed.
Arroyo
  • Last login:November 26, 2025, 09:34:25 pm
  • Budgets are boring
« Reply #3 on: January 04, 2019, 05:21:25 pm »
What are you using to amplify the signal from d-sub out of your computer into the monitor to get the 2.4-3V signal?
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #4 on: January 04, 2019, 05:25:07 pm »
I am not amplifying at all.  Was unaware I should be.
Arroyo
« Reply #5 on: January 04, 2019, 05:31:04 pm »
Maybe you don’t, I thought I had understood that most arcade PCB’s output a 2.4-3V signal and that the signals for most consumer electronics/computers outputted a peak to peak signal of 0.7V.
Here’s a quote from the guy who sold me the transcoder I bought for the CRT TV:
“Arcade video input signals need some special care on the RGB lines, while sync can be directly connect (whether its horizontal sync or HV Sync). This transcoder expects an standard RGB input signal of 0.7Vpp, however most arcade boards operate at around 2.4-3V on the RGB lines, so you will need to drop this voltage accordingly with a resistor divider or insert series resistors on the RGB lines (the transcoder terminates the RGB signals at 75 ohms).”
So I would have thought that an arcade Chassis would be expecting a higher voltage signal.
« Reply #6 on: January 04, 2019, 05:42:45 pm »
VGA sync signals are TTL (+5V).
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #7 on: January 04, 2019, 05:52:23 pm »
This is a video of what I’m getting.
« Reply #8 on: January 04, 2019, 06:01:15 pm »
That's not a sync issue. The picture of the Windows background doesn't roll. It looks like a very heavy interference.
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #9 on: January 05, 2019, 07:27:13 am »
Thanks Calamity!
Ok, so chalk up that craziness to a crappy vga cable
New problem though.  Any idea what those vertical stripes are?  They are stationary, don’t move or waiver.
Note: this monitor has been recapped.
