Author Topic: Coin Mech not working  (Read 2392 times)
safx
  • Last login:January 17, 2019, 05:42:23 am
« on: November 29, 2018, 11:45:18 am »
Hi,
I have an Arcade with JAMMA and MAME running on a PC ( GroovyArcade) via a J-PAC.
This has run fine for a couple of years.
My coin mech button (i have  switch behind it, dont need to put a coin in) and also the coin mehc LIGHT has stopped working.
For the last few months i had to switch ON/OFF a few times, for the light to come ON. Last week it just stopped turning ON.
Something was failing and ended up failing.  Nothing else has failed.
So i still boot up in GroovyArcade, and can play any game with Joysticks and all buttons working !
I should say that when i say "coin Mech" i am really only talking about the switch behind it. I do not use the coin mechanism.
Do you think my J-PAC is bad ? Only Coin is not working ?
What do you recommend ?
Thank you
« Last Edit: November 29, 2018, 11:48:26 am by safx »
  • Bitches love Centipede
Re: Coin Mech not working
« Reply #1 on: November 29, 2018, 12:02:14 pm »
Thank you
Buy a multimeter and watch some youtube videos on basic electrical troubleshooting. :cheers:
%Bartop
safx
« Reply #2 on: November 29, 2018, 12:11:17 pm »
Are you implying that my JAMMA board has a malfunction component, and some random youtube videos are enough for someone read its layout and understand where its gone wrong ? That is quite an assumption, and it wont help me much.
I dont get the 12V in my switch, as even the lamp does not turn on.
So either the J-PAC gone wrong (i hardly believe it) or it seems to be a problem from the JAMMA board itself.
So for Arcade Gurus : do you think this can be visible, as a component failed, or even better a fuse?
jennifer
« Reply #3 on: November 29, 2018, 12:38:39 pm »
Actually Neph gave you good advice... And most likely you will find a bad ground to your switch. (Depending how that's wired of course).
« Last Edit: November 29, 2018, 12:43:30 pm by jennifer »
« Reply #4 on: November 29, 2018, 01:31:29 pm »
You are the one making assumptions instead of following tried and true basic troubleshooting steps.  :cheers:
%Bartop
  • Last login:Today at 12:27:33 pm
« Reply #5 on: November 29, 2018, 02:22:01 pm »
I find it is always helpful to ---steaming pile of meadow muffin--- on the advice of long time forum members.
aldub516
  • Last login:November 29, 2018, 03:32:46 pm
« Reply #6 on: November 29, 2018, 03:33:18 pm »
lol.. ive learned college level skills from watching "Random youtube videos" lol...
errryone wants the easy way out
barrymossel
  • Spectrum
« Reply #7 on: December 01, 2018, 03:45:53 am »
I even watch YouTube videos to learn skills I don't even need in the first place.
safx
« Reply #8 on: December 02, 2018, 01:32:35 pm »
Just to close this thread,  i found the culprit.
The arcade switching power supply is dead.
Dont know how the J-PAC can work without this, but it does. The only button i am missing is the Coin1 button.
I will replace it with a new one because they are very cheap on fleabay.
Tx
