Author Topic: Supermodel-UI setup wheel ferrari thrustmaster 458  (Read 6419 times)
jackiabu
  • Last login:May 18, 2025, 02:29:49 pm
    • http://jackiabu.blogspot.com/
« on: November 13, 2018, 10:15:40 am »
HI
i try to setup my  ferrari thrustmaster 458 on Supermodel-UI Sega model 3. so far no success.
left and right on the wheel respon good but no gas or breaks , i try allmost evrey thing on the setting menu under RACE.
by the way, the wheel playing good all other racing mame games on my cab.  :hissy:
baritonomarchetto
  • Last login:February 20, 2026, 01:04:30 am
Re: Supermodel-UI setup wheel ferrari thrustmaster 458
« Reply #1 on: November 13, 2018, 11:19:18 am »
Supermodel UI is no longer supported so I would suggest you to run and setup M3 games with a cmd file
jackiabu
« Reply #2 on: November 13, 2018, 11:27:28 am »
thanks for this info....but  its make no sense that  all button on the wheel  respon good and can mapping. only gas i need to mapping. it's something that i missing :dizzy:
baritonomarchetto
« Reply #3 on: November 14, 2018, 12:45:34 am »
When debugging hardware/software you shold proceed in an additive way more than subtractive. This means that you need to start from the slimmest hardware and software. In this case hardware is you wheel (ok) software is UI+emulator. Remove the UI.
MrThunderwing
  • Last login:February 21, 2026, 03:10:59 pm
« Reply #4 on: November 14, 2018, 03:41:17 pm »
I've had issues before where a new build of Supermodel wouldn't respond to my gas and brake inputs when I was trying to configure them with my pedals, even when I specifically used the command for dinput devices (supermodel -config-inputs -input-system=dinput) when I was configuring all my settings. I can't remember how I fixed it now, I think I either just copied and pasted a config file across from an older Supermodel with all my wheel settings in.
jackiabu
« Reply #5 on: November 16, 2018, 06:11:42 am »
I really appreciate if you remember ::) no luck on CMD allso...
MrThunderwing
« Reply #6 on: November 16, 2018, 07:39:09 pm »
Try seeing if you can get Supermodel to recognise the gas and brake axes in the first place. I explained how to do this to someone else on the Supermodel forum some time ago, you can read it here: https://www.supermodel3.com/Forum/viewtopic.php?f=3&t=49&start=530#p11331
jackiabu
« Reply #7 on: November 17, 2018, 05:13:49 am »
OK thanks . but what this parameter means -config-inputs ?  i get only config folder in cmd, and there is ini file. how do i get to the configure inuputs in the cmd?
68hc11
  • Last login:April 13, 2019, 12:18:47 pm
« Reply #8 on: November 29, 2018, 07:01:33 pm »
I am struggling with a similar issue trying to interface the Immersion FFB board to Supermodel.  The M2 emulator works fine on both gas & brake pedal, so I know it may be done but the manual -config-inputs calibration method doesn't seem to help and every combination of input I've tried so far doesn't work, I've tried builds 502 and the current with the same results.
What is the difference between the M2 emulator input routine and the Supermodel? I wonder.
I need to check some more but I swear that the M2 emulator switches gas/brake after set up.
Any insight appreciated.
68hc11
jackiabu
« Reply #9 on: December 02, 2018, 02:17:41 pm »
68hc11
update me please, so far it's seem that no one has solved this problem ;D
