Author Topic: Non-interactive start up  (Read 4166 times)
jokerz4fun
  • Last login:January 18, 2022, 06:00:32 pm
  • Im surprised I haven't electrocuted myself yet.
« on: November 04, 2018, 09:11:11 am »
Hey guys. I just started a new Megatouch ion project and when it boots it hangs at entering noninteractive startup. I've tried different hard drives, memory, and I O boards. And I still have the same issue any ideas? Is this bios related? I did log into the BIOS at startup and everything seems to be set to normal default. Motherboard is Asus A7N8X-LA
mahkeymike
  • Last login:Yesterday at 03:58:50 pm
Re: Non-interactive start up
« Reply #1 on: November 05, 2018, 08:38:21 pm »
Looks like its hanging right before the sensor and hardware checks. If i had to guess faulty Motherboard. Check to see if there is any capacitors that are swelling.
orizzle
  • Last login:September 21, 2020, 07:20:41 pm
« Reply #2 on: November 07, 2018, 08:42:42 am »
"Cannot enable port 1, maybe the usb cable is bad"
Never seen that, but I'm guessing something connected to the motherboard or the mobo itself is holding it up.
jokerz4fun
« Reply #3 on: November 07, 2018, 10:49:07 am »
I worked on it last night and believe it or not it was the USB cable. I swapped it out and it booted right up. Just need to figure some issues out with the io board and I should be all set! thank you guys for all the help I really do appreciate it.
