Author Topic: I-PAC2 Firmware Upgrade Mode - Which Pin?  (Read 1448 times)
pacboy
  • Last login:December 24, 2019, 09:18:52 am
« on: October 13, 2018, 04:45:37 pm »
On the Ultimarc website, it shows how to put the I-pac2 into firmware upgrade mode using the "hard" method:
https://www.ultimarc.com/fwupgrade.html
The picture shows a wire connecting the pin on the lower left to the ground screw.  I have the newer version of the I-pac2 , which has been redesigned and now has two rows of 10 pins:
http://ultimarc.com/ipac1.html
Which pin on the new design should be connected to ground?
Thanks for any advice.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: I-PAC2 Firmware Upgrade Mode - Which Pin?
« Reply #1 on: October 13, 2018, 09:01:54 pm »
The newer boards dont have this "Hard" method. It should not be necessary.
If there is a problem upgrading firmware I can assist via email.
andy@ultimarc.com
