Author Topic: Can't get Groovymame to start [solved]  (Read 2663 times)
NinpouKageBunshin
  • Last login:October 06, 2018, 09:22:23 pm
« on: October 01, 2018, 03:35:06 pm »
edit: just needed to use opengl, though it's still not working properly; games are running as if throttling is disabled when it isn't :/
« Last Edit: October 01, 2018, 07:38:41 pm by NinpouKageBunshin »
  • Last login:Today at 04:45:28 pm
Re: Can't get Groovymame to start [solved]
« Reply #1 on: October 02, 2018, 02:18:09 pm »
GM won't work properly on OpenGL. Leave video as auto (it defaults to d3d) and try to fix the issue from there.
NinpouKageBunshin
« Reply #2 on: October 02, 2018, 09:14:34 pm »
That's odd. GM ONLY works with opengl in my setup. Setting directly to d3d or auto only flashes a black screen upon launch for me. Using a 6670, if it matters. I'm having other issues too, but I'll start a new thread for those when I get back home. Thanks for the reply!
krick
  • Gotta have blue hair.
« Reply #3 on: October 02, 2018, 10:43:26 pm »
Windows 7 and up requires installing the DX 9.0c redistributable package because the Direct X 10.0 and above are NOT backwards compatible.
Install this package from Microsoft:
https://www.microsoft.com/en-us/download/details.aspx?id=8109
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
NinpouKageBunshin
« Reply #4 on: October 03, 2018, 12:13:46 am »
Thanks! This is a fresh Win 7 re-installation so I hadn't thought to do that yet. Fingers crossed that it'll help me work out some kinks
« Reply #5 on: October 06, 2018, 04:29:16 am »
Also, make sure to download my full package, not just the binary alone from someone else. Some files in the hlsl folder have changed recently so if you mismatch versions it won't run.
