Author Topic: GM and Marquees with Super Resoultions  (Read 2462 times)
Vincefaro
  • Last login:July 17, 2025, 11:40:56 am
« on: September 26, 2018, 01:39:29 pm »
Does anybody have a setup that has a Marquee with GM using Super Resolutions and the Marquee is visible during gameplay? I am trying to do this .
I have GM .201 . , using HS, and Hyper Marquee with EDS, and Since I have switches to Super Resolutions I can keep the Marquee working once I select a game. Does anybody have this working?
I have numscreens .  1
And I have my two monitors  setup like this .
screen0                   \\.\DISPLAY1
aspect0                   auto
resolution0               auto
view0                     Primary
screen1                   \\.\DISPLAY2
aspect1                   auto
resolution1               1920x1080
view1                     Marquee_Only
  • Last login:January 21, 2026, 10:59:40 am
Re: GM and Marquees with Super Resoultions
« Reply #1 on: September 26, 2018, 03:55:52 pm »
So, are you trying to make GM show your marquees, or are you using Hyper Marquee instead? You can't use both methods at the same time.
Vincefaro
« Reply #2 on: September 26, 2018, 04:04:20 pm »
Hi Calamity , I want HM to display the Marquees , not GM. I had this working before I started using Super Resolutions which are great by the way. I thought my ini would take car of this. But it does not seem to work.
« Reply #3 on: September 26, 2018, 04:21:57 pm »
The options you posted are meant to show your marquees through GM, not Hyper Marquee. In other words, now you have to programs trying to draw on your marquee.
Anyway I highly doubt something like Hyper Marquee can run without breaking GM completely.
Vincefaro
« Reply #4 on: September 28, 2018, 04:06:58 pm »
Ok, So I my new plan wiil be to have
numscreens = . 2    and have Marquees in MAME display when in the game , and Hyper Marquee display Marquees outside Mame . Now I need to figure out how to use .lay files and set them to fit my Marquee screen.
anchounio
  • Last login:January 04, 2026, 08:28:56 am
« Reply #5 on: September 29, 2018, 06:13:14 pm »
Hi
What marquee lcd did you buy?
Is a lcd capable of working with Groovymame and CRT Emudriver?
« Last Edit: September 29, 2018, 06:21:55 pm by anchounio »
Vincefaro
« Reply #6 on: October 01, 2018, 11:16:35 am »
I bought an LCD direct from China
rcstarsgroup.com. Does it work with GM and emudriver ? Yes but that question is the reason for this post , it works however , you will need to use Mame to view the marquees in Mame not with a third party software like , hypermarquee .
