Author Topic: Easyget vs Sanwa Buttons  (Read 2282 times)
dkoiro
  • Last login:September 09, 2018, 04:27:14 pm
« on: September 07, 2018, 01:31:54 pm »
I'm struggling with a decision on my first cabinet build, and hope you all can help.
I've read that the Sanwa buttons are among the highest quality buttons for fast response, but I keep coming across the EasyGet buttons and joysticks when searching for Sanwa.
Are they the same, or is there a difference in quality between tbe two?
The Easyget buttons are consistently much less expensive than the Sanwa, but I don't wish to buy them if they will need replacement in the near future.
Drnick
  • Plodding Through Life
Re: Easyget vs Sanwa Buttons
« Reply #1 on: September 07, 2018, 04:37:46 pm »
Leave those Easygets alone, they plain nasty. Very similar to the ones I used on my first attempt at a bartop, needless to say I soon ripped them out and replaced them with some happs.
To help us more , What thickness control panel do you have?  What experience are you trying to replicate?
Sanwa are usually in japanese fighters,  Do you want to replicate the Japanese fighter feel, or are you more used to american machines,
Then there is style of button, Shmups for example would normally use a nice short leaf switch, but Streetfighter 2 was Microswitch,
So much more to think about before deciding on what make to go for.  But trust me on the Easygets,
dkoiro
« Reply #2 on: September 07, 2018, 05:20:47 pm »
Thank you, that confirms my suspicions! I’m building a bartop out of 3/4 in MDO, so I know I need the screw-type, not snap-in type.
As far as feel, I was leaning toward the faster response of the Japanese-type over the Happ, I don’t care as much about the shape of the button, or whether it makes a “click” when pressed.
I’m not totally opposed to Happs, but do want to install joysticks that can be switched between 4-way and 8-way, and saw that Sanwa had that option.
  • Last login:November 21, 2025, 10:39:28 am
« Reply #3 on: September 07, 2018, 07:35:44 pm »
The Sanwa JLFs can be switched, but not easily.  Look up a youtube video on it.
Sanwa JLW can be switched back and forth if you don't tighten the screws down all the way.
Some people add washers so the screw head can't drop into the notch intended for it.
Titchgamer
« Reply #4 on: September 08, 2018, 03:17:19 am »
The Ultimarc mag stick + switches easily between 4 and 8 way.
But its not your standard feeling stick either it has a very short and snappy throw.
