Author Topic: Gingerballs 2.1 the rebuild starts  (Read 48704 times)
« on: August 26, 2018, 04:23:36 pm »
Skip to the next page for 2.1 stuffs.
The other ball drops ;)
This is just a prototype of the upcoming kit from Haruman. I'm putting it together to see what needs tweaking.
Started by gluing the base together:
Put the head together too (and test fitted the Pin2DMD):
some base paint:
Mounted the head frame cross beam:
Some more paint, and test mounted the exhaust fan:
quick Carbon fiber wrap on the front (I'll trim it off the sides after I whip up some artsies)
Just trying to figure out the internal layout:
After I figure out where everything is going to go, I'll drill the holes for the power supply intake, speakers, etc
« Last Edit: August 18, 2021, 12:26:06 pm by Malenko »
Re: Gingerballs 2.0 Advanced Prototype
« Reply #1 on: August 26, 2018, 04:54:58 pm »
Looks great so far.  Why is the back so tall?  I thought people used one monitor for the back and the DMD (top 1/2 for the back screen and bottom 1/2 for a fake DMD).  I haven't been following pin builds in a while though...
Laythe
  • Last login:February 18, 2026, 06:54:56 pm
« Reply #2 on: August 26, 2018, 05:09:22 pm »
Nice!
Given the kits are cut on a machine, would a couple tabs of finger joint for the 90 corners of the lower box be worth doing?
« Reply #3 on: August 26, 2018, 05:16:26 pm »
Modular kit, you can pick the head you want and the body you want (based on screen sizes). Ginger 1.0 had the DMD's played over top of the backglass image on the same screen.
This head is for a "real" DMD , it goes better with a bigger base. Ideally they'll be a third head with speakers too, but nothing is set in stone.
I didnt want to buy another monitor for a prototype build, so its got a tall DMD head :)
Nice!
That's a Haruman question. I'll let him answer.
Laythe
« Reply #4 on: August 26, 2018, 05:43:20 pm »
Sure - apologies, I don't mean to sound like I'm trying to tell Haruman how to do his job or anything.  I'm sure he will know the pros and cons.  I thought it might make assembly easier if they had a few tabs, and that the prototype phase might be the time to say so.  If it's already been considered and is hard to mass produce a consistent fit, I totally understand.
That's such a charming form factor.  Gingerballs was awesome, and I'm glad more people will have a chance to try something like it.
« Reply #5 on: August 26, 2018, 05:58:00 pm »
I would think the CNC couldn’t cut the finger joints square enough.
Ian
  • Last login:February 27, 2026, 11:36:05 pm
« Reply #6 on: August 26, 2018, 08:39:07 pm »
Watching this with much anticipation.
  • Last login:Yesterday at 02:19:38 pm
« Reply #7 on: August 26, 2018, 09:42:10 pm »
If you can mount the board perpendicular to the x axis instead of flat on it you can cut proper finger joints. Most CNC machines don't allow for this because it cuts down on the total work area.
« Reply #8 on: August 26, 2018, 10:07:52 pm »
Hmmm... that makes sense. You’d need a pretty long/deep Z axis though.
Laythe
« Reply #9 on: August 26, 2018, 10:09:59 pm »
I think that you can also do fingers if you're using a waterjet or laser.  (I didn't know if he was CNCing the kits that way, or on a mill / router.)
  • Last login:March 14, 2026, 08:11:32 pm
« Reply #10 on: August 26, 2018, 10:15:59 pm »
Hate it.
« Reply #11 on: August 26, 2018, 10:21:25 pm »
Hate it.
I hate your face.   What do you hate about it?  The head height cant be shaved much and keep the DMD :(
jdbailey1206
« Reply #12 on: August 27, 2018, 07:46:48 am »
I hate that you have your workstation organized and I don't.   ;D
« Last Edit: August 27, 2018, 07:53:07 am by jdbailey1206 »
« Reply #13 on: August 27, 2018, 08:44:47 am »
its only organized because I had to get it that way to start building the bathroom in the background :p
« Reply #14 on: August 27, 2018, 02:34:42 pm »
I don't get the point of these virtual machines, and if you're going to build one, why would you bother with something that isn't full size or nearly so?
Are you planning on playing 'real' games or stuff specifically developed for the virtual pinball platform?  I've yet to play a video pinball that didn't bore me by the second ball besides Windows Space Cadet 3D Pinball.  Even those hybrid Multimorphic machines are complete garbage.
« Reply #15 on: August 27, 2018, 02:40:58 pm »
I enjoy emulated pinball, I know its not the same but its still fun.  I play both "virtualized real games" and purpose built software games (Pinball FX)
I can keep this upstairs in my office , if I want to play the real thing I'll go down to the basement and have at it.
« Last Edit: August 27, 2018, 03:16:01 pm by Malenko »
« Reply #16 on: August 27, 2018, 03:03:18 pm »
That's what it gets down to doesn't it?  You either enjoy playing virtual pinball and pinball based software games OR YOU DON'T.  Trying to compare a real pinball machine with a Vpin is a bit pointless they’re obviously not the same experience.  I like real pinball but I also like pinball software games.  Every time I play my favourites on a PC I think how much more fun they'd be with better controls.  That's the point of these.
I was quite inspired by your first one of these Malenko - mini Vpins are good if you have less space for a full size table, real or virtual.
« Reply #17 on: August 27, 2018, 03:10:41 pm »
I am not a fan of vpins myself. My dad loves playing pinball on his cell phone. One of these would be great for him. He would love it. He moved to Chicago with my mom and no money from North Dakota. He took a job driving a cab, and he worked at Chicago Coin for awhile.
« Reply #18 on: August 27, 2018, 06:23:30 pm »
I played on the original Ginger balls. Besides the sharp edge that needed a fixin, it was probably one of my favorite vpin experiences. I personally don't ever want to next to a 50" monitor flopped horizontally in my living room. It is just too much screen to be huddled against. Gingerballs 1.0 was just easy to follow, had snappy controls and really captured all I wanted out of a fake pinball experience.
jdbailey1206
« Reply #19 on: August 28, 2018, 10:21:57 am »
Two things have to be formulated from this discussion:
  • PBJ needs to make a Virtual Windows Space Cadet Pin
  • "***Build what you dig, bro. Build what you dig.***"
« Reply #20 on: August 28, 2018, 02:01:16 pm »
  • Vigo enjoys playing with Ginger Balls
FTFY
  • Bitches love Centipede
« Reply #21 on: August 28, 2018, 02:53:34 pm »
Price. For what a full size VP would cost, you could buy a few real pins. Virtual pinball blows overall, but a mini VP cab is the best way to play. I played a full size PBFX at Zapcon... ---fudgesicle--- being that close to a screen that big. VP is a novelty, just like MAME.
%Bartop
nexusmtz
« Reply #22 on: August 29, 2018, 02:30:45 am »
At that high price, you'd think that those PBFX machines would have had decent frame rates. At least when you build it yourself, full or mini, you have control over that.
keilmillerjr
  • Web Developer.
« Reply #23 on: August 29, 2018, 08:18:06 pm »
Cool.
« Reply #24 on: September 09, 2018, 06:13:46 pm »
Did some mathing and geometrifying  to figure out where the power supply inlet hole was going to go:
used a hole saw bit:
fits like a glove!
figured out where to put the bracing batons in:
then clamped them all down
To note, another set of larger batons go overtop, locking the PS in place and acting as a platform for the FFB solenoids.
This is  the rough footprint Im going to be using. I will be mounting the FFB control board and the IPAC and doing the wiring much better than GB 1.0
Pulled everything out and prepped for paint, getting the side super smooth
and the first of many many many coats is on:
« Reply #25 on: September 09, 2018, 08:47:55 pm »
Yay ! This is going to be my go to project when I build one of these.  Looking good so far. Subscribed.  :cheers:
« Reply #26 on: September 10, 2018, 08:37:56 pm »
Now that the paint is dry, I decided to fancy pants it up a bit. Added underbody LEDs (white only, not RGB)
There will be legs on the bottom to elevate it a bit and let the light glow bright underneath. I had a TON of extra from real pin projects so it was a free upgrade :)
The prototype kit only has a slot for 1/4" thick wood for the bottom. While this maximizes inside space for guts it leaves nothing to screw into. Production kits will likely have 1/2" for the base, or 2 pieces of 1/4" , one for putting the kit together and an additional 1/4" piece to sit inside the bottom.
I just cut down 1/2" batons screwed the mobo into them, and then glues them down into place.
Next I'll be doing wire management and trying to keep everything tidy before I add the top level batons that the FFB solenoids will screw into. Current plan is to bottom mount the solenoids and have the PF monitor sit on top of it. We'll see how well it works in practice over just working in theory ;)
« Last Edit: September 10, 2018, 08:41:52 pm by Malenko »
« Reply #27 on: September 10, 2018, 10:40:11 pm »
Sorry if I'm jumping ahead, but what monitor/tv brand/model should go in these? Vpin noob here. :-\
« Reply #28 on: September 10, 2018, 10:58:27 pm »
the backglass doesn't matter that much, Im using an OLD Dell 4:3 LCD with bad viewing angles. for the playfield I have a 60Hz ASUS brand LCD with great response times. If you have the budget it only gets better with a 4K monitor. a 120 Hz or higher also helps.
« Reply #29 on: October 17, 2018, 06:42:18 pm »
Shoved everything inside....
mobo lost settings, so back display is disabled in BIOS  -_-
Got that sorted:
underbody LED looks great:
I need to go through and change the backglasses to exclude the bezel and DMD, but the external DMD is rawkin
Wife tested and approved!
« Reply #30 on: October 20, 2018, 11:17:47 pm »
I started dabbling in ginger's side art......
jmike
« Reply #31 on: October 21, 2018, 08:42:57 am »
       Been watching this from the start. Looks great!
Loving those LEDs (might have to add those on mine)
« Reply #32 on: October 21, 2018, 09:08:45 am »
What size screens would I need to have laying around to use this kit?
« Reply #33 on: October 21, 2018, 07:45:34 pm »
PF is 24" , Backglass is 19" 4:3
Pin2DMD in the DMD hole.
« Reply #34 on: October 23, 2018, 05:23:01 am »
Wow this looks really great.  How hard is setting up the software?  I really wish I had room for a pin like this in my house...
Sent from my iPad using Tapatalk
« Reply #35 on: October 23, 2018, 10:11:12 am »
Really the setup is easier than ever. A ton of tables now run on VPX , so you no longer have to keep 3 or 4 versions of VP9 including physmod5. VPX also unifies the tables so that there is no more "cabinet" version, desktop version, etc  I'll be making the change from PinballX over to PopUp for front ends.
I'm not trying to put words in Haruman's mouth but I believe the kit is still set to be modular.
So in theory there should be 1 or 2 bases to pick from (24" screen or smaller and 27" screen) , and at least 2 heads, maybe 4. Widescreen, Widescreen + DMD, 4:3, and 4:3+DMD.
I just need to set up a buncha tables, figure out the lockdown bar, and maybe build a stand with real pinball legs for it.
« Reply #36 on: October 23, 2018, 09:32:22 pm »
Got the DMD colorizations working (most of the time)
WWF Royal Rumble colorization by CB3
« Reply #37 on: October 24, 2018, 09:57:37 am »
Looks great!  Really like how this is coming together.
« Reply #38 on: November 12, 2018, 07:09:54 pm »
art mock up, not worrying about borderlines and laser beams and ufos ;p
« Last Edit: January 07, 2019, 05:43:51 pm by Malenko »
« Reply #39 on: November 13, 2018, 01:00:49 am »
That is definitely not shoddy.  ;)
