Author Topic: Rowe CD100E #7 on Keypad does not work  (Read 2438 times)
runtzcf
  • Last login:August 15, 2018, 06:38:48 pm
« on: August 15, 2018, 05:18:40 pm »
The Number 7 on the keypad of my Rowe CD100E stopped working.  I tried taking apart the switch inside the button and cleaning the contacts and this did not work.  I then changed out the switch with another switch that works and still the #7 would not work.  So I know it is not the switch inside the button.  Does anyone have an idea of whats going on here?
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe CD100E #7 on Keypad does not work
« Reply #1 on: August 16, 2018, 07:40:13 am »
Hello runtzcf,
You need to check the keyboard  and looms for dry joints and connection issues.
Regards
Alan
Alan Hood
ami-man
UK
« Reply #2 on: August 16, 2018, 10:20:52 am »
resolder the connector where the ribbon cable connects and check for broken traces between the button and that connector.
maybe go ahead and resolder the plug for the keyboard on the "title rack/keyboard interface assy board" too. check the ribbon wire for broken wires while you are at it.
Short of that... it's remotely possible you have an issue with the interface board.
