Author Topic: Bluetooth mod kit for original controllers from 8bitdo  (Read 46581 times)
  • Last login:January 22, 2026, 12:55:00 pm
Re: Bluetooth mod kit for original controllers from 8bitdo
« Reply #40 on: December 14, 2018, 05:04:49 pm »
Any updates on functionality with your 3-4 player receivers, opt2not?
I've been swamped at work all week, having to put in OT. I'll have a chance to check out the new firmware this weekend and post results.  :cheers:
KenToad
  • Last login:Today at 04:39:23 pm
  • Flap Flap Flap
« Reply #41 on: December 15, 2018, 03:03:04 pm »
Those of you that have 8bitdo branded controllers: Have you had any issues with the d-pads?
I've seen several YouTube videos from people, for instance the guys at My Life in Gaming, stating that the PCB's need to be modified (partially covered with tape) in order to prevent unwanted diagonals.
You can find video demonstrations of this with people holding right and having Mario or whatever duck unintentionally.
« Reply #42 on: December 16, 2018, 01:58:44 pm »
Tried updating to the latest firmware, didn’t work in the 3rd or forth slot.
@KenToad
What multitap are you using? The long one? Or the one that looks like bomberman’s head?
Are you playing on an original SNES, SNES Jr., or SuperNT?
KenToad
  • Flap Flap Flap
« Reply #43 on: December 16, 2018, 07:49:59 pm »
Bummer, I'm playing with the long multitap on an original Snes with SD2Snes.
Even just a single receiver won't work in position 3 or 4?
Thanks so much for checking
« Reply #44 on: December 17, 2018, 03:56:44 pm »
Yeah, single doesn't work. Hmm, I'm using the long multitap with a SuperNT, but I'm going to dig out my original SNES and test it as well. I wonder if it's actually the SuperNT not giving out enough juice on controller lines to support the Multitap...
KenToad
  • Flap Flap Flap
« Reply #45 on: December 17, 2018, 09:52:48 pm »
That's cool to know that the SuperNT at least works with the multitap with wired controllers. Does a single receiver work in any port on the multitap with the SuperNT, or at least player 2 in 2 player mode?
I ordered a second SNES retro receiver from Amazon. It should get here Wednesday and I'll report whether or not it works with the multitap. If it does, I think I'll be ordering some more DIY kits soon.
« Reply #46 on: December 17, 2018, 10:02:19 pm »
The receivers seem to only work in the 2P slot, in either multiplayer switch setting on the multitap.  P3, P4 and P5 doesn't work. The receivers just rapidly flash white when it's powered up, and won't go into paring mode (regular blue flashing LED).
I've got an original SNES and SNES jr that will host my next test. Stay tuned  :cheers:
KenToad
  • Flap Flap Flap
« Reply #47 on: December 17, 2018, 10:38:30 pm »
Can't wait to read the results!
I'm actually checking Craigslist for CRT's and scheming how I might get one into the house without causing the wife to have a fit.
I'm outputting composite into a 40" flatscreen, which really sucks for the SNES. The NES actually isn't quite as bad, although you see all the overscan garbage.
But a big ass tube TV and Bluetooth receivers for original controllers? Just heaven. And once in a while I'd like to play some Duck Hunt properly.
KenToad
  • Flap Flap Flap
« Reply #48 on: December 19, 2018, 01:07:03 pm »
I just tested two SNES retro receivers simultaneously in ports 4 and 5 of the super multitap and they work perfectly.
Any updates on your end, opt2not?
« Reply #49 on: December 19, 2018, 02:40:53 pm »
Gonna dig into my storage in the next couple days to test it out. I can barely get anything done during the week with my schedule around this time of year, but I'll update you guys on my findings sometime later this week.
Arroyo
  • Budgets are boring
« Reply #50 on: January 01, 2019, 10:58:02 pm »
Well, my plan to have a unified way to play emulated games with a variety of controllers has suffered a setback. Retroarch, at least, sees each Retro Receiver as it's own numbered entity, based upon the order that they were plugged in, which will undoubtedly randomize with every reboot of the PC.
I was really hoping that Xbox 360 controller #1 would always be seen as such in a generic way by Windows.
My dream was to have all the controllers attached via usb as 360 controllers. That way, whatever controller I activated first would be seen as controller #1 by the emulator/Retroarch and Windows. Then, it would be a snap to use any controller with any system, as they would all have the same mapping. Has anyone dealt with this problem before and maybe found a better solution?
Based on everything posted here I was pretty fired up and bought 2 NES and SNES controllers and as everyone has stated they work awesome, especially on a CRT ;-).
I was also troubled buy the Windows device ID issue but stumbled upon this:
https://www.reddit.com/r/RetroArch/comments/8wj03s/usb_device_id_change_on_reboot_breaking/
Been testing it today and so far after a number of restarts and re-plugs it’s working brilliantly.  Hopefully this means no more device mapping again!
Only issue I have now is I can’t seem to have all 4 controllers connected to my Bluetooth dongle at once.....only the NES or the SNES.
KenToad
  • Flap Flap Flap
« Reply #51 on: January 02, 2019, 09:48:34 pm »
Cool, Arroyo!
I might order one or two more SNES kits and one more NES kit. Right now I'm waiting for my Retrotink 2x to ship and planning to install several floating shelves to hold my consoles w/flashcarts. The wireless options are perfect, but I still haven't decided how to handle N64's pathetic 7 ft. cord or whether I want to try a wireless 3rd party Genesis controller.
KenToad
  • Flap Flap Flap
« Reply #52 on: January 07, 2019, 02:59:17 am »
I finally made up my mind to order enough goodies to have a set of 4 SNES pads and receivers, as well as 2 NES pads and receivers.
Just messing around with the pads and rediscovered that the SNES are by far my favorite controllers, especially without the wires, so I'll be happy to use them on the PC.
Even if all 4 don't work simultaneously through the multitap, it will still be excellent to have two hooked up to each system.
I haven't tested it yet, but the software link that Arroyo posted seems like it will be a perfect fit. Thanks!
« Reply #53 on: January 07, 2019, 09:13:59 pm »
Shoot, I didn't get back to you with my tests.  I did pull my SNES JR out of storage to test it during the holidays, but I completely forgot about it through the haze of Bourbon and Glogg.
 :dizzy:
I'll fire it up tonight if the missus doesn't have me pull down all our Christmas decorations.
« Reply #54 on: January 08, 2019, 03:15:11 am »
Nope. Doesn't work on my original SNES Jr console. Same results. I've tried connecting just one receiver to ports 3, 4 or 5th and I still can't get it to work.  So something is going on with how the multitap handles those ports, perhaps less voltage output?  I'm not sure.
@KenToad  when you get your set, let us know if your multitap works with all 4 retro receivers. I'd actually be happy if it does, then I'd know it's my multitap not functioning properly.
KenToad
  • Flap Flap Flap
« Reply #55 on: January 08, 2019, 12:23:53 pm »
I wonder how similar your 8bitdo controllers are to the DIY kits I'm using? I was able to hook up a WiiU pro controller to ports 3-5, though, so I doubt that is the issue.
Isn't the SNES Jr. different in several ways from the original model SNES that I'm using? Maybe just video output? I don't remember.
Thanks so much for checking and for posting that video. My DHL delivery is supposed to happen Thursday. Maybe I'll be able to assemble and test before the weekend.
I've been looking into the new wireless genesis controllers from 8bitdo. They are 2.4g rather than bluetooth. I tend to avoid 3rd party controllers, but they look decent quality and are a pretty good deal at $24 each shipped from Amazon. And they include the receivers. I ordered a pair of extension cords, but the wires are just irritating by now. Guess I'm getting spoiled.
It's all over YouTube that 8bitdo controllers notoriously have bad d-pads. Diagonals are far too easy to hit because the contacts on the pcb's are too large. People make them smaller with bits of tape and stickers. That hasn't been a problem at all with the DIY kits. Have you noticed any issues with accidentally hitting diagonals with your SN30 pads?
« Reply #56 on: January 08, 2019, 01:56:28 pm »
They shouldn't be any different.
Yeah, just video. The Jr should support all the peripherals that the regular SNES supports.
All of them have great d-pads, after a bit of breaking-in. 100% playable in Contra 3, SF2T, platformers. You name it. I’m very fickle with d-pad quality, and these have not disappointed me.
The d-pad complaints are either vastly exaggerated, or perhaps the quality of the later batches have went down.  I’m really wondering if the later batches had quality issues. Mine are from the initial opening sales, first batch.
Osirus23
« Reply #57 on: January 09, 2019, 06:12:34 pm »
I have several 8bito SN30s and have had zero complaints about the d-pads or anything else. Closest thing to OEM I've ever used in regards to third-party Nintendo controllers.
KenToad
  • Flap Flap Flap
« Reply #58 on: January 10, 2019, 12:27:03 pm »
That's great to hear that the 8bitdo controllers have worked well. YouTuber's can be oddly finicky. Look up videos comparing 1 vs. 2 chip SNES's for example.
What do you guys think about 2.4g wireless vs. Bluetooth? That's what the 8bitdo genesis controllers are using and what the upcoming wireless N64 controllers will use. Didn't the old Wavebirds also use 2.4g?
« Reply #59 on: January 10, 2019, 02:05:37 pm »
They did and they were fantastic!
I dunno about the 8bitdo 2.4g controllers, but if it's different than the bluetooth, I'd be interested in hearing why.  Though it wouldn't matter in the long run since I already committed to the BT version.
KenToad
  • Flap Flap Flap
« Reply #60 on: January 11, 2019, 01:01:17 am »
All 4 SNES Bluetooth controllers work through my multitap with retro receivers.
Now I just need a group of buddies that want to play Super Bomberman.
« Reply #61 on: January 11, 2019, 01:12:11 am »
Really?? Dammit. My multitap must be faulty then.  :angry:
KenToad
  • Flap Flap Flap
« Reply #62 on: January 11, 2019, 04:53:40 pm »
So it works with wired controllers, but not the retro receivers in ports 3-5? It still seems worth investigating hooking it up to an original SNES, rather than the Jr. version, if you haven't already done that.
To be fair, I'm going to have the 3rd and 4th SNES controllers hooked up to the PC for emulators 99% of the time.
KenToad
  • Flap Flap Flap
« Reply #63 on: January 14, 2019, 10:14:47 am »
I was playing Chip and Dale's Rescue Rangers 2 with my son yesterday and had my first issues with the NES bluetooth pads running through the 4 score in 2 player mode. Sometimes my character wouldn't stop moving after I stopped pressing a direction. Some inputs were delayed. My son didn't seem to have any issues. I haven't had any issues running only one retro receiver through any port in the 4 score.
I moved the retro receivers to the standard controller ports and that seems to have resolved it.  :dunno
« Last Edit: January 14, 2019, 10:49:02 am by KenToad »
« Reply #64 on: January 16, 2019, 08:31:53 pm »
Hey, could you record a video of this working with all 4 receivers?  Because I just got a reply back from 8bitdo stating that "Multitap does not provide power for four receivers.".
I don't know why they couldn't have come clean from the beginning. Shady business practices, I guess.
KenToad
  • Flap Flap Flap
« Reply #65 on: January 17, 2019, 10:54:20 am »
Maybe they don't have a multitap setup with an OG SNES?
*Edit* I should add that I haven't been able to test this setup yet with 3 other players. However, just trying it out myself, I can't detect any lag or other issues.
« Last Edit: January 17, 2019, 11:26:57 am by KenToad »
« Reply #66 on: January 17, 2019, 02:11:46 pm »
Thanks for the upload.  I've forwarded it and asked them to test on an OG SNES.
I still haven't gone into my storage for my OG. I guess I'll have to do that soonish. It just sucks because I sealed it in plastic because it CIB and I mainly use the SNES Jr or SuperNT (yeah, I caved and bought one of those Anal-logue devices).   :lol
KenToad
  • Flap Flap Flap
« Reply #67 on: January 17, 2019, 06:46:44 pm »
The Super NT looks pretty amazing. I will admit that I haven't bought any 3rd party hardware, except these DIY kits, because I'm happy with emulators. It's mainly the novelty of using the original consoles that led me to find a decent solution for hooking them up.
« Last Edit: January 17, 2019, 07:02:20 pm by KenToad »
KenToad
  • Flap Flap Flap
« Reply #68 on: January 29, 2019, 12:48:26 am »
8bitdo is making retro receivers for Genesis/Megadrive, due to release at the end of February. Preorders are up on Amazon for $20.
KenToad
  • Flap Flap Flap
« Reply #69 on: February 08, 2019, 02:34:54 pm »
When the retro receivers are plugged into the PC, they are always seen as being on, no matter whether your controller is currently powered on or not. What this means is that you cannot reorder your Xinput controllers by turning them on and off. The receivers must be physically unplugged from the usb connections. That basically breaks PC functionality for me. I don't want to have to unplug a retro receiver to use a different xinput controller when I'm playing a steam game, for example.
The Wireless xinput dongle I got from Microsoft supports 4 Xbox controllers and you can change the order at any time by simply turning the controllers off and then on again in the desired order. I also don't want to have to use extra drivers or software to make a fixed order for these retro receivers. I guess it was too much to ask that 8bitdo would design their products with optimal flexibility for PC usage, since that seems to be an afterthought anyway. I suppose that I could ask their support staff if they could possibly update the firmware, but for now I've gone back to using my Microsoft connector and Mayflash PS3 controller connector, both of which have been excellent.
I went ahead and preordered one of the new Genesis / Mega Drive retro receivers through Amazon.
I also ordered a Sega Teamplayer, Sega's multitap, new in box from Amazon Prime for $20. Even though they had a picture of the box and listed it as new, I really didn't expect it to be shrinkwrapped and have all the documentation, stickers, etc.
After smelling the 1994 air, I tested it out and found that it works, but its usage is incredibly convoluted. Rather than being a simple 2p-4p or 5p binary switch like the NES and SNES multitaps, you have a 6 position switch labeled Extra, A, B, C, D, and Multi. It also has two short wires instead of one, labelled as Controller 1 and Controller 2. The crazy thing is that you can't plug both wires in when you have a game that's compatible with the Teamplayer. You only plug both wires in if it's a multiplayer game that doesn't have teamplayer compatibility. And then you use the extra setting instead of multi. You use multi mode when you have a teamplayer compatible game, but you plug the controller 1 wire into port 1 if you have up to four players and leave the other wire hanging, but you have to move the same wire over to port 2 if you have up to 5 players and then plug player 1's controller into port 1. The instructions don't say, but I'm assuming that ABCD switches are for choosing what controller to play as 1st player in single player only games. That's just a guess, though (I'll look it up eventually).
Between this and the 32X released that year, just further proof that, by 1994, Sega had completely lost their minds.
I'll test the retro receiver with the Teamplayer when I get the receiver, hopefully later this month.
*Edit* I looked it up. Apparently, EA is the reason for the complexity, as they made their own multitap adapter called the 4 Way Play, which sounds sexual, and refused to support Sega's peripheral (which initially was more simple and didn't have twin wires to connect to the console). I was also correct about the ABCD switch being for choosing which controller would be used as 1st player, so that you could have other controllers or peripherals, such as the mega mouse, plugged in and switch between them on a per game basis, although that still doesn't seem all that practical.
*Sigh* This will all be worth it if I can get a gang together to play some NHL '94.
« Last Edit: February 08, 2019, 03:14:23 pm by KenToad »
Arroyo
« Reply #70 on: February 08, 2019, 05:21:17 pm »
Did you try the link that I posted to the software that maintains the device ID order?  Works really well for me, you can place it in the subfolder of any emulator so that it works across multiple formats.
KenToad
  • Flap Flap Flap
« Reply #71 on: February 08, 2019, 11:21:57 pm »
Does it work for steam games? I'm also just not sure I want a fixed order for controllers.
Arroyo
« Reply #72 on: February 09, 2019, 07:14:37 am »
It’s worked on every program so far.  Why wouldn’t you want a fixed order for controllers?
KenToad
  • Flap Flap Flap
« Reply #73 on: February 11, 2019, 10:58:13 am »
I don't want a fixed order because it's inconvenient, basically. Right now I have a Microsoft wireless dongle that supports 4 Xbox 360 controllers and a Mayflash PS3 dongle that supports 4 PS3 controllers through Directinput. In both cases, whatever controller I power up first becomes 1st player and displays its order via LED on the controller.
If I do a system-wide fixed controller order, then I might have to label my controllers or change the order for specific games. If I do a program specific fixed order, then it's similar hassles and the work of setting up a bunch of configurations.
I still appreciate the link and I might eventually set it up for Retroarch, but for now just plugging in a retro receiver when I want to use a specific retro controller for a steam game or something seems like the best option.
KenToad
  • Flap Flap Flap
« Reply #74 on: February 28, 2019, 09:47:59 pm »
I got the mega drive/genesis retro receiver today and it's been great so far plugged directly into my model 1 "High Definition Graphics" Genesis.
I'll test it with the Team Player tomorrow.
KenToad
  • Flap Flap Flap
« Reply #75 on: March 01, 2019, 01:01:24 pm »
I tested the MegaDrive Retro Receiver with Gauntlet IV and NHL '94 with my Bluetooth modded US 6 button controller Mk-1653 and 3 wired controllers plugged into the Team Player and so far it worked perfectly. The everdrive only seems to recognize inputs when the Team Player is set to "Extra," though. It worked for me to switch to "Multi" after the game booted.
The MegaDrive Retro Receiver seems to be nicely put together. It's sleek and solid.
KenToad
  • Flap Flap Flap
« Reply #76 on: March 04, 2019, 10:46:36 am »
One of my 4 SNES mod kits has started malfunctioning. The D-pad stopped working. The other buttons work fine.
I'll email customer support, but I'm not hopeful that this will be resolved without a bunch of time and energy expended.
KenToad
  • Flap Flap Flap
« Reply #77 on: March 05, 2019, 11:15:33 am »
I got a reply from 8bitdo advising me to update the firmware to version 6.10 and reset the controller by holding the start button down for 8 seconds. I did both of those things and of course they didn't fix the problem. However, the firmware update notes mention that they "Fixed input lag with more than 3 players problem." Of course, you can't update the firmware without opening up the Nintendo controllers to access the mini usb ports on the modkits and it seems like I probably should update them all, so it's a bit irritating that they didn't solve this issue before releasing the products.
I'm out of the 30 day return window, but it hasn't even been two months. We'll see what they say, but at least the process is reversible, right?
« Last Edit: March 05, 2019, 11:19:39 am by KenToad »
gamepimp
« Reply #78 on: March 05, 2019, 07:04:52 pm »
Hopefully they will send you a new kit if they can’t fix it with software. Aside from the battery dying, the kit should last for a very long time. Speaking of the battery, you have done a full charge right? These Bluetooth controllers do some funky stuff when the charge is low.
KenToad
  • Flap Flap Flap
« Reply #79 on: March 05, 2019, 09:52:28 pm »
Yeah, the first thing I did was to charge it up, but I wasn't aware that bluetooth controllers are known for issues when the charge is low. I'll definitely keep it in mind if I run into trouble in the future. Thanks.
