Author Topic: Strange 'cut-off' across top of screen.  (Read 3140 times)
ckong
  • Last login:October 19, 2020, 06:48:09 pm
  • Retro Games forever!
« on: June 04, 2018, 05:50:21 pm »
OK, I'm running Groovymame with an Ati radeon 4550 HD card and CRT Emudrivers on a Windows XP PC, spitting out 15 Khz through a homemade VGA > RGB Scart cable (including 5V + 100 Ohm resistor and 12V from the PC power supply).
I'm testing this setup with 3 European 21" RGB Scart TV's (2x Philips and 1x Sony) and 1 true 15K 27" Barco DCD2740 monitor, and I'm having a particular issue with the Sony TV and the Barco monitor. Where the 2 Philips TV's present a good overall picture and geometry, the Sony TV and the Barco monitor show a 'cut-off' section across the top of the screen, see attached picture on the Barco displaying a test screen in 640x480 resolution.
What causes this and how can I solve it?
« Last Edit: June 04, 2018, 05:57:03 pm by ckong »
  • Last login:November 21, 2025, 06:06:43 pm
Re: Strange 'cut-off' across top of screen.
« Reply #1 on: June 04, 2018, 05:59:52 pm »
it's just a little overscan... dial down the vertical size a tad and call it good.
Paradroid
  • Last login:July 12, 2025, 08:11:33 pm
    • SCART Hunter
« Reply #2 on: June 04, 2018, 06:20:59 pm »
Open up Arcade OSD and fiddle with your vertical porches. Looks like your monitor is cropping a line or two. You should be able to shift the image down using Arcade OSD and then update your GroovyMAME monitor specs accordingly.
ckong
« Reply #3 on: June 04, 2018, 08:46:53 pm »
Both thx for your replies.  :) I never did mess a lot in ArcadeOS, but I will try to do that.  8)
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
« Reply #4 on: June 05, 2018, 07:17:30 am »
Typical for Sony tronitrons, all Sony TVs that I had/have have the same problem. Instead of creating modelines use alternative custom range instead of arcade_15.
Look here http://forum.arcadecontrols.com/index.php/topic,148828.msg1638016.html#msg1638016
« Last Edit: June 05, 2018, 07:22:34 am by haynor666 »
