Author Topic: Switchres query  (Read 4187 times)
nierlaika
  • Last login:May 26, 2018, 11:43:19 am
Switchres query
« on: May 23, 2018, 05:44:08 pm »
Hey guys,
I'm still not too sure what Switchres does, I have an nvidia card in my cab build so afaik it won't help for me.
Is there anyway to stop the switchres pop up saying "switchres: could not find a video mode that meets your specs" every time I try to start a game.
Doesn't seem to stop gameplay or anything, just gets in the way lol. I went through the ini file and changed a few 1s to 0s, even removed the section and tried again, but that made no diff
buttersoft
  • Last login:Today at 08:22:19 pm
  • Is running at 15kHz
Re: Switchres query
« Reply #1 on: May 23, 2018, 07:38:30 pm »
Open the mame.ini file and edit the core switchres options. I think the one you want to turn off is...
modeline generation    0
Or you can just specify a "resolution" where you see that variable, either in mame.ini again, or for particular game/driver inis.
Switchres is the modeline generation engine within GM. It looks at the native modeline of a game, and the stretching/scaling options in MAME.ini, compares the result to the list of video modes in your system, picks one that suits and recalculates the framerate to match the original game. If it can't do that, it complains :)
« Last Edit: May 23, 2018, 07:42:12 pm by buttersoft »
  • Last login:Today at 04:07:49 pm
Re: Switchres query
« Reply #2 on: May 24, 2018, 03:24:48 am »
Sometimes I wonder if the correct behaviour should be preventing GM to start altogether.
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
Re: Switchres query
« Reply #3 on: May 24, 2018, 04:25:42 am »
I like those programs that require you to read the documentation first before they tell you what the "make it work" configuration kill switch is.
Re: Switchres query
« Reply #4 on: May 25, 2018, 05:08:29 am »
What kind of monitor are you using? Is an LCD?
nierlaika
Re: Switchres query
« Reply #5 on: May 25, 2018, 05:25:20 am »
Yeah, LCD with nvidia gfx  :(
I've read that my experience will be "way more limited and unreliable than the standard one." but I've been told this is the most accurate software whilst still compatible with newer CAVE games.
« Last Edit: May 25, 2018, 05:29:34 am by nierlaika »
nierlaika
Re: Switchres query
« Reply #6 on: May 25, 2018, 05:38:39 am »
No joy with the resolution option, I did try the modeline generation option before with the same result.
Even deleted the whole section from the ini and no effect.
Re: Switchres query
« Reply #7 on: May 25, 2018, 06:17:06 am »
Create a new mame.ini, from command line:
groovymame.exe -cc
Then edit this in mame.ini:
monitor lcd
modeline_generation 0
aspect 16:9
(I'm assuming it's a 16:9 LCD, if it's something else edit accordingly)
nierlaika
Re: Switchres query
« Reply #8 on: May 25, 2018, 06:59:06 am »
groovymame.exe -cc
monitor lcd
aspect 16:9
You legend!
not too sure what you mean about the first few lines, but I edited my ini file that I already had and that worked.
Thanks again,
