January 25, 2026, 10:05:03 am
If I had to guess he needs to remove the front piece in order to laminate it? Is it being laminated with wood grain? DeL
I put the front panel on backwards. Speaker grille should be on the right side and the coin door is shifted on the left on a Nintendo cabaret. I guess its not a big deal if nobody noticed
Fix it. You'll always notice it.
Quote from: leapinlew on May 16, 2018, 08:19:41 pmFix it. You'll always notice it.+1 if it bothers you now, it will bother you later.
