Author Topic: The big perfect GM frontend quest  (Read 5383 times)
Amplifuzz
  • Last login:November 24, 2018, 09:30:46 pm
« on: May 04, 2018, 04:47:11 pm »
Hi all, I'm looking for the right frontend ... too many choices as usual.
It will go into a a couple of GM-powered Mamecabs, one vertical one horizontal, with joystick + buttons layouts.
So, it should:
- be light on resources
- look good on low 15khz CRT resolutions, both horizontal and vertical
- support different gamelists (I'm liking Lightspeed Mamelister to generate them so far), each with its own mame.ini to reconfigure the controls for each
- be simple, almost barebones, (no hyperspin-like bling), quick to navigate with just joy + buttons
Any tips? TIA
keilmillerjr
  • Web Developer.
Re: The big perfect GM frontend quest
« Reply #1 on: May 04, 2018, 05:06:16 pm »
Not really groovymame related.
My recommendations are attractmode, retrofe, and big blue front end.
Check out the all killer no filler lists. I also converted it to tag list for attractmode.
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #2 on: May 04, 2018, 05:48:33 pm »
GameEx can be as busy (HS Style) or as simple as you want..
buttersoft
  • Last login:Yesterday at 05:57:35 pm
  • Is running at 15kHz
« Reply #3 on: May 04, 2018, 07:15:43 pm »
My recommendations are attractmode...
This. Very light, and comparatively easy to work with :)
keropi
  • Last login:December 28, 2022, 11:06:35 am
« Reply #4 on: May 04, 2018, 07:28:04 pm »
I use Maximus Arcade in my cab - it's too bad development stopped... it's really old-school though no fancy stuff
funkycochise
  • Last login:October 22, 2019, 07:35:18 am
  • 8 bits generation
« Reply #5 on: May 04, 2018, 10:33:04 pm »
mala with custom 15k low res layout. 320x240
nothing fancy just m4v video in selection
layout has evolved a bit since (i never did another video)
fcobenitez
  • Last login:May 23, 2022, 12:36:40 pm
« Reply #6 on: May 04, 2018, 11:25:12 pm »
Hello,
Where can I find these lists? Looks like it's just what I need :D
Thanks in advance
  • Last login:Today at 02:25:46 am
« Reply #7 on: May 04, 2018, 11:46:15 pm »
makya
  • Last login:December 16, 2025, 10:25:53 am
« Reply #8 on: May 06, 2018, 12:29:52 pm »
AdvMenuPLUS
terranigma
  • Last login:March 20, 2019, 04:03:17 am
« Reply #9 on: May 06, 2018, 02:10:38 pm »
EmulationStation with Gbz35 theme.
krick
  • Gotta have blue hair.
« Reply #10 on: May 07, 2018, 12:51:38 am »
I've started playing around with Attract-Mode.  Is there a simple, clean, modern theme that has large-ish text that is readable on a low-res 15KHz arcade monitor.  I'm looking for something tasteful (some might say sterile) and functional.
Also, does anyone know what the "console version" is?
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
RobeeJ
  • Last login:August 20, 2025, 03:36:59 am
« Reply #11 on: May 07, 2018, 03:27:56 am »
I use the Nevato theme on Attract Mode, it's very nice. I do have an LCD monitor at 1600x1200 but it uses marquees to show each game so should work nicely on lower resolution displays.
m.andrade1
  • Last login:April 10, 2025, 09:05:35 am
« Reply #12 on: May 07, 2018, 01:13:43 pm »
AdvMenuPLUS simple, fast, only complain it flashes the desktop on the enter and exit of the game.
keilmillerjr
  • Web Developer.
« Reply #13 on: May 07, 2018, 10:04:28 pm »
I created two layouts for attractmode: mvscomplete and flavors. Both were designed to work well in my Neo Geo k7000 and well as my high res iMac I use for development. See my sig.
2.3 made the app split into two different derivatives. One shows the console. Useful for troubleshooting and list management. Other does not show console window, and doesn’t include console access either. It’s kind of stupid. Download them both and drop in same folder.
Edglaf
  • Last login:April 23, 2024, 03:38:27 am
« Reply #14 on: May 08, 2018, 11:17:34 am »
After having tried many frontends, attract-mode is the best for me, at least in my win7 cabinet. I ended up hating those spectacular hyperspin style things, because they bring you lofts on problems relating to video interference and performance and, at the end they forget the essential thing: gaming. Although i use A. Mode in a lighweight and sober config you can do whatever with it very easily.
empardopo
  • Last login:November 17, 2025, 01:32:25 am
    • My personal forum
« Reply #15 on: May 08, 2018, 02:34:33 pm »
I agree 100% with you.
Enviado desde mi MI MAX 2 mediante Tapatalk
