Author Topic: Problem with hiscore plugin  (Read 7075 times)
Jack
  • Last login:March 07, 2025, 06:28:36 pm
  • See You Space Cowboy..
« on: February 13, 2018, 12:16:53 pm »
I've activated the option in plugins for the hiscore support but it doesn't save the score after i exit the game by pressing (ESC) i'm using the last version of GM on Windows 10. How can i fix it? Thanks.
  • Last login:Today at 02:55:46 pm
Re: Problem with hiscore plugin
« Reply #1 on: February 13, 2018, 12:36:13 pm »
Did you configure "highscore.ini" and put "highscore.dat" in the right folder?
There is no high score patch now, it's all in the LUA plugin. You do need the hiscore.dat still though.
Try running MAME with the verbose switch and see if it is launching the plugin and if it is finding the hiscore.dat file.
Thanks RobertJ it was good to have it confirmed that the high score patch was no longer needed, I did some more research and found that I had my folder hierarchy incorrect, all fixed now old and new high score working :)
You can also set the location the hi scores are saved by using the "hiscore.ini" file.
example "hiscore.ini"
hi_path $HOME/.mame/hi
dat_path $HOME/my/hiscore/data/path
Only hi_path is currently used (Hi Score save location).
The dat_path (dat file) is looked for in the current directory and then in the hiscore plugin directory.
You could enable the dat_path by uncommenting line #51 in the hiscore lua script (init.lua).
Jack
« Reply #2 on: February 13, 2018, 01:12:49 pm »
I don't have hiscore.ini, the hiscore.dat is located in \plugins\hiscore\hiscore.dat .. i'm really confused about what i have to do other than activate the plugin.. i did some research and is more confusing because people talk about differents methods with differents versions of mame etc.. sorry..
funkycochise
  • Last login:October 22, 2019, 07:35:18 am
  • 8 bits generation
« Reply #3 on: February 13, 2018, 01:19:57 pm »
what’s your game ?
Jack
« Reply #4 on: February 13, 2018, 01:22:45 pm »
what’s your game ?
I tried Puzzle bobble 1 and 2, and i see that in the directory "hi" now there are pbobble.hi and pbobble2.hi files, but i guess they are not loading?
I did everything i had to do
in mame.ini
# SCRIPTING OPTIONS
autoboot_command
autoboot_delay            0
autoboot_script
console                   0
plugins                   1
plugin                    hiscore
noplugin
and in plugin.ini
# PLUGINS OPTIONS
cheat                     0
cheatfind                 0
console                   0
data                      1
dummy                     0
gdbstub                   0
hiscore                   1
layout                    0
portname                  0
timer                     0
Still nothing..
« Last Edit: February 14, 2018, 01:52:30 pm by Jack »
Jack
« Reply #5 on: February 14, 2018, 01:55:00 pm »
I tried to make a log file but the txt i get is empty.. any suggestion? thanks
RobeeJ
  • Last login:August 20, 2025, 03:36:59 am
« Reply #6 on: February 15, 2018, 04:58:01 am »
Are you using savestates?
Jack
« Reply #7 on: February 15, 2018, 05:24:35 am »
Nope, i realized that some roms work with nvram and it takes time before it saves scores.. like the puzzle bobble games, too bad.. bubble bobble scores work fine, so i guess the plugin is working fine.
