Author Topic: [4/1/2024] -Pi4/5 Support Incoming -Major League SkeeBall -- SkeeBall Controller  (Read 247794 times)
Rberry45
  • Last login:August 02, 2024, 10:18:55 pm
  • The name is Hackenbacker, actually, Sir.
 Nipsmg, I just want to say that I absolutely love this software. :applaud: Incredible work! I purchased an old Skee Roll machine and the software has brought this back to life. Just installed the optical sensors and am adding the 100 point holes.
You possess a skill set (programming) that I do not possess. I have a request. I may be asking for something that is fairly easy to do, or may be impossible, or perhaps has an easy solution that I am just not aware of, but here is the ask:
For those that are familiar with Virtual Pinball, VPX Pinup Popper front end has an option to shut down the computer from the menu screen. In short, I can place the start up file in the start up folder, and start, run and shut down the computer without ever using the keyboard or mouse (minimal interface with Windows). While I do have your application file in my startup menu, I am manually closing the program, then manually shutting down windows. Is this something that could be done with this software? Perhaps as an option on the main menu screen?
Not a criticism by any means. Your software made my day, heck, week when I recently stumbled upon it.  If you need testers in the future, just ask. Thank you again for this wonderful software! Scott
Rberry45
Bounce Issues with Optical switches - may help someone with conventional whisker switches as well...
I just finished converting to optical switches and had issues with random multiple scoring. The solution for me was to go into windows, Settings, Accessibility, Keyboard, selected "Filter Keys", and switched "Ignore Unintended Keystrokes" to "On", and lastly set "Wait before accepting repeated keystrokes" to "0.3 seconds". After a restart, no more multiple scoring.  Different versions of Windows (I am running Windows 11) may be worded differently, but the same theory applies. Since the IPAC board for my setup is considered a keyboard to the computer, this eliminated the double bounce scoring issue for me.
Hope this helps someone else if they are experiencing bounce scoring.
Jstgilstrap
  • Last login:August 04, 2024, 02:03:20 pm
I did the same thing But now if you tap the right or left arrow to fast it wont let you scroll through the games. You have to hit it at a slow rate.
IceBalls
  • Last login:June 01, 2025, 06:32:52 pm
Update on the Ice-Ball project...
As mentioned in an earlier post, Ice-Ball does not have an opto-sensor on each pocket. The three top pockets (50 and 100R and 100L) actually share only 2 sensors. Therefore some logic needs to be implemented to determine what pocket is actually correct and send the appropriate key press.
I decided the easiest way to do this would be to run all sensor outputs to an Arduino Leonardo board and write the logic on there. Tapping into the 5V opto outputs under the playfield wasn't too bad either. The Leo boards also have the ability to act as a HID and simulate a USB keyboard. So this solution allows me to write the necessary logic and replace an i-PAC2.
Once it was proven out, I swapped the original marquee for a 27" monitor and tucked a small Windows PC behind it to run MLS. Right now, I just have a small wireless keyboard to send the ESC/ENTER/LEFT/RIGHT/UP/DOWN commands, but I plan to add buttons at some point. Audio is also connected back to the Ice-Ball speaker so it sounds great.
The machine has been getting a lot more play now. Thanks for your work developing this!
rick_bungle
  • Last login:February 07, 2026, 08:56:30 pm
Any one have an issue with the program closing its self. If I keep the program up for a bit it just will close. its even closed during a game play.
I think that's a memory leak -- It happened randomly. I might have a build that fixes that, I'll have to check.
Did you ever check to see if you have a build to correct the memory leak?
lawrence_jeff
  • Last login:December 14, 2024, 06:38:53 pm
Great stuff @nipsmg
I recently got a cheap used home game with a broken scoreboard (the sportscraft ~$100 type). I converted the switches with the aid of a raspberry pi pico to trigger keyboard input from the existing switches and then used your app.
Its a non commercial so doesn't have 100 targets but I managed.
Spoon34
  • Last login:December 30, 2024, 11:16:27 pm
I just picked up a Skee-Ball Lightning and am excited to implement this upgrade to it! I've read all the pages and links to other examples. It does not come with any electronics boards, but each hole does have a OMRON EE-SPY415 (optical sensor?). So I can use those, right?
I also have a Raspberry Pi 4B and 5 if I can use those.
Otherwise -  a Windows PC/PC on a stick.
Here's what I think I need after reading the forums...
Power Adapter - for powering the optical sensors?
IPAC 2 - To convert the Optical Sensors into Keyboard inputs. Is that correct?
Any guidance on what else I'd need?
Thank you TONS!!
  • Last login:Today at 06:33:32 pm
If they're still working, you should be able to use them.
Keep in mind that these sensors are now marked "Obsolete" for Lifecycle so replacements will probably be hard to find.
Datasheet: https://www.mouser.com/datasheet/2/307/en-ee_spy415-1670610.pdf
Looks like 5v Vcc should work.
Datasheet indicates max Output Power Dissipation = 250mW * 8(?) sensors ==> 2W.
W = V * A ==> 2W = 5v * __A ==> 2W/5v = 0.4A ==> 400mA.
Leave yourself some wiggle room -- use a power source that can supply at least 500mA.
NOTE:  You'll probably want to tie the ground from the power source to the ground for your encoder so both are operating at the exact same voltage.
It might be a bit of overkill for a skeeball machine, but it will work.
So will any other active-low encoder like an Arduino with a good keyboard firmware like this one.
Spoon34
Well, either I smoked 2-3 of these Omron optical sensors, or they were all bad to start! I managed to get 1 to respond, once. Thank you for your help this week however. I hooked them directly up to the 3-wire leads on this USB Joystick Encoder that arrived quickly from Amazon. https://www.amazon.com/dp/B01M2X88QP?ref=ppx_yo2ov_dt_b_fed_asin_title . However, I can't get them to respond, and my laptop USB3 port is powering the USB encoder, which is powering these switches... too much current?
Anyway, I'm going to order some switches ASAP to get this going before Christmas. I'm liking the idea of whisker switches. Any advice on switches that can be powered by the aforementioned USB Joystick Encoder would be much appreciated!
It is clear that you do not know what you are doing with this stuff.   :o   ???   :banghead:
Plugging a 3-pin optical sensor into some random 3-pin connector on a 100% unrelated PCB is not a way to test if the sensor is working.
If your plan is to slap random electronic stuff together and hope it works without releasing the magic smoke, then let me know now so I don't waste any more of my time.
If you have a multimeter and are willing to take the necessary time to systematically work through things, I can help you.
- You should consider starting a thread in Project Announcements for that so we don't fill up Nipsmg's thread with the many off-topic back and forth posts that this process will require.
I'm not sure if the encoder you linked to is an "active low" or "active high" device, but there's a decent chance you won't be able to draw enough amperage through it to power all of the optical switches.  If you insist on using that encoder, you'll have to reverse engineer the LED buttons so you can use that info to reverse engineer the encoder PCB.  Might be better to use that encoder for some other project and find one with known specs and pinout for you skee ball setup.
You can easily pull that off if your target is Christmas 2025.
If you mean Christmas 2024 . . . don't bet on it.
Before you write off those Omron switches, you should at least properly test them.
- They were originally chosen because they work mounted on that play field and with those balls.
If the Omron switches are bad, the next thing I'd recommend is the beam break sensors mentioned earlier in this thread.  More info and 3d printable mounts at https://www.thingiverse.com/thing:2932740.
Otherwise, here are some things to keep in mind if you insist on using physical switches:
- Physical switches will usually need more maintenance than optical switches in the long term due to the impact.
- You'll need to mount physical switches in a way that the wiring is protected and the ball reliably hits the arm to trigger the switch without damaging the mount.
- There is one type of wire arm microswitch that I've found that will handle the impact of the skee balls without the arm popping off -- Zippy 1351 -- but you probably don't want to order them from here on Amazon.
« Last Edit: December 21, 2024, 05:11:30 am by PL1 »
Spoon34
I scrapped the science project AtomicPi and found a core i5 Dell Latitude on Marketplace for $60. Omron sensors were bad - had already tested them with multimeter. Problems solved.
$30 in new optical sensors - https://www.amazon.com/dp/B09JZCYCCN?ref=ppx_yo2ov_dt_b_fed_asin_title
$60 laptop - FB Marketplace
$50 27" monitor - FB Marketplace
$25 arcade button/joystick USB kit - https://www.amazon.com/dp/B01M2X88QP?ref=ppx_yo2ov_dt_b_fed_asin_title
$5 in new number stickers - Hobby Lobby
and $40 in wiring - https://www.amazon.com/dp/B07GCZV4BS?ref=ppx_yo2ov_dt_b_fed_asin_title
All set! Thanks for your help along the way, and this incredible game!!
JRS
  • Last login:December 18, 2025, 09:21:56 am
I have been reading this thread for a while now. Just a few days ago I was able to pickup an IceBall machine and am ready to start the conversion. I'm super excited use MLS to get this machine back up and running. Thanks to everyone who has blazed the trail for me to follow!
« Last Edit: May 28, 2025, 10:42:56 am by JRS »
nipsmg
  • Last login:February 15, 2026, 06:33:19 pm
  • ROONEY!! ERRGH!!
    • Arcadia
Cool let me know if you need help.
SteveMakesStuff
  • Last login:August 25, 2025, 07:26:20 am
Hello nipsmg!
I've had your software for quite some time, but as of yet have only had it running on the bench.
I've been a lurker here for years, but have rarely had much to contribute. I just really enjoy all of the cool stuff you guys make.
I have a big school dance coming up, and I'm finishing up two machines this weekend.
I cannot for the life of Me remember where to find the pin definitions for My USB joystick and button controllers.
I'm trying to set these up for classic skee ball only for simplicity's sake.
These are running on i3 compute sticks plugged into an HDMI Monitor.
If you could point me in the right direction, I'd sure appreciate it.
Also, I wanted to see what your link was for tossing you a few dollars for all of your hard work.
Thanks! Steve
RBC
  • Last login:February 16, 2026, 06:46:42 pm
I am working on modding a SmartBall machine that I purchased that has a defective display.
Planning on swapping out the display for a 27 inch monitor and running your software on an Intel I3 NUC.
Wondered if possible to implement automatic ball release, maybe with a usb relay board..
Amazon has a bunch of different versions (single and multi channel) that are fairly inexpensive;
I can add a button to energizer the ball release solenoid but it would be great to automatically release
balls at start of new game.  Maybe Also, drive a strobe and activate the ticket dispenser when "Winner"
is displayed and announced, with the same board?
I think it would really add to the "Arcade" feel for the machine.
I have been testing the software on a PC just using the keyboard and mouse for input and have
been very pleased.  Looking forward to getting the game running on the machine.
Thanks for all your great work.
JRS
Hello NIPSMG,
The software is excellent, and my family particularly enjoys the Zapp game.  I’d love to customize the sounds a bit.  For the Classic game, I noticed there are scoring sound clips for each value but they aren’t used in the game.  Am I able to turn those on somehow?
I took a demo video to show a friend, and sharing here so you can see my setup.  I also want to do some cool things with lighting. Thanking addressable LED strips that react when you score.
https://imgur.com/a/gE2qExq
Addressible LED lighting has been a plan for some time now.  I have already prototyped the hardware using an ESP32 and some custom arduino code along with the .net serial interface to control it.  I just don't have the time to add it.
nipsmg, I was  wondering if you ever ended up implementing the lighting you mentioned. I used an Arduino Leonardo to read the inputs for my machine and I have a few pins left that I could use to control LEDs. I was hoping some game info is or could be sent back on the USB. Even just knowing if a game was active or idle would go a long way to adding lighting affects or controlling the ball release solinoid.
