Author Topic: Can somebody help me to build my arcade?  (Read 2933 times)
BigLouis1971
  • Last login:December 29, 2017, 05:00:05 pm
« on: December 23, 2017, 05:32:43 am »
I'm building a bartop arcade based on Raspberry Pi 3 and retropie. What I would like to know is if there's an application where I can design and previsualize my cabinet and later print the templates. I'm a newbie working with MDF and I'm having trouble cutting my fist side piece. I want to cut my first side piece close to perfection and use it as a template to cut the rest with my router and flush trim bit. Thanks in advance.
SlammedNiss
  • Last login:Yesterday at 06:57:09 pm
  • Mine Drags the Ground!
Re: Can somebody help me to build my arcade?
« Reply #1 on: December 23, 2017, 05:35:03 pm »
villageidiot333
  • Last login:September 14, 2025, 12:09:44 pm
« Reply #2 on: December 23, 2017, 10:16:23 pm »
I’ve seen many use cardboard for sides. Trace it to MDF and just clean up the lines. The use a trim bit on router to replicate the other one exactly
paigeoliver
  • Awesome face!
« Reply #3 on: December 23, 2017, 11:58:29 pm »
It is a tabletop, doesn't matter, you can screw up the whole thing and you are out like $12 worth of wood. The tools to even make one that doesn't look like garbage cost 10 times as much as the wood does.
  • Last login:Today at 03:48:48 am
JDFan
« Reply #5 on: December 24, 2017, 03:19:22 am »
^ This - figure cardboard boxes can be picked up free - draw out the side the way you want it on the cardboard and cut out with an exacto knife - If you mess it up start over till you get a shape you like.
